Results 1 to 5 of 5
Thread: fuel tanks
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default fuel tanks
    Just wondering if a VN wagon fuel tank would fit under a VK wagon? Are the V6 and 5.0L tanks the same, wats the difference? I'm after a solution to get a tank under my wagz with a return line for the EFI 5.0L.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by DANNY8 View Post
    I cant say for a wagon but I am running a tank from a VQ Statesman in my VK. There are very few/slight changes between models mainly cosmetic stuff so I would say it would fit but you will have issues with filler neck. I suggest you grab one out of a VL wagon it would be a more of a bolt in solution.
    When I fitted my tank one tank strap fitted fine the other needed extension to make it fit due to different locating point.
    cheers
    Scott
    DANNY8's Avatar
    Apr 2004
    What about pumps, do I just use the VQ pumps (I got a VQ 5.0L donor car) with the VL wagon tank? Is there a pump inside the tank and one outside?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    That depends on the tank you use, My VQ tank uses 2 pumps.
    Low pressure internal pump then a high pressure external one.
    I think the VL uses 1 external only.
    Im pretty sure the VQ tank i have uses 2 pumps as its a long range tank and the first pump is used to pump the fuel out of the bottom of the tank.
    cheers
    Scott
    VK Commodore
    Apr 2009
    VL tanks have a low pressure inside and hi pressure out side, im fairly positive on this as i had a VL before this.
  1. large capacity fuel tanks
    By VH commodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-03-2008, 08:19 PM
  2. fuel tanks
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 11:51 PM
  3. fuel tanks
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-01-2007, 09:27 PM
  4. fuel tanks
    By drewboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2006, 05:23 PM
  5. Fuel Tanks
    By VBSL79 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-12-2003, 09:59 AM
