Results 1 to 2 of 2
Thread: vk problem
    vk commodore
    Apr 2006
    Default vk problem
    iv got an efi vk on lpg. it was goin fine until i swapped the engine with a reco 1 that i had. the reco 1 was a standard black carby motor. the carby motor has been in another car since the rebuild and ran fine. now in the vk with the efi attached it runs poorly. it has a very rough idle after giving it a decent rev. any ideas wot the problem might be?
    thanks
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Cam profile is different between Carb & EFI but usually not enough to make a huge difference.
    Does it change between car warm & cool?
    Whats performance like?
    what rpm is it idling at?
    I would first of all check
    Earthing for the computer
    Air flow meter there is an idle mix screw (hex) that might need adjusting but only as a last resort.
    check for air leaks
    check TPS adjustment
    check your vacumn hoses are fitted correctly & not leaking
    Make sure all your vacumn sensor/switches are opperating correctly
    Check your vacumn advance on your dizzy and make sure its not leaking.
    cheers
    Scott
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. VT Problem
    By VTSPACK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2007, 04:25 PM
  5. Oil Problem
    By zammits ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 09:23 PM
