Results 1 to 5 of 5
Thread: Aircon problem
    Pez's Avatar
    Pez
    Pez is offline Reppin
    VK
    Feb 2009
    Northern Beaches, Sydney
    Default Aircon problem
    hey all
    in my vk the aircon wont change so it comes out through the vents. i can move the switch but it doesnt move from the one that goes onto your feet.
    The aircon and heater works fine its just it wont change.
    anyone know whats going on?
    thanks
    VK Commodore
    Apr 2009
    Id love to find out the answer to this, same thing happened in my ex gfs car.. no matter where you put the lever on it still came out all vents.
    Pez's Avatar
    Pez
    VK
    Feb 2009
    VK SL EFI/ Monaro CV8
    Sep 2005
    It sounds like either the vacuum motor that controls the flap for air direction (feet, face or windscreen) has either seized, or one the vacuum lines has disconnected. There is one vacuum line from the engine that runs into the mode control panel in the dash. There are also about four or five other vacuum lines that run from behind the control panel to the vacuum motors connected to the heater box behind the dash. It can be a bugger of a job to fix. I have sent some attachments to help you out. These are from the VK factory workshop factory manual.
    Attached Thumbnails Attached Thumbnails Aircon problem-vk-heater-mode.jpg   Aircon problem-vk-heater-control.jpg   Aircon problem-vk-heater-box.jpg
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I have a really good diagram on my site from an olt tech talk article.
    Also the actuator on the aircon controls could be leaking.
    cheers
    Scott
  1. vp aircon problem?
    By ben k in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2008, 07:10 PM
  2. vp aircon problem
    Last Post: 03-06-2008, 06:50 PM
  3. yet another vs aircon problem!
    By brisgold in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2008, 09:11 AM
  4. Aircon Problem
    By fudlop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2006, 10:32 PM
  5. VT Aircon Problem!
    By Carnage in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2005, 01:07 PM
