Results 1 to 9 of 9
Thread: diff and speedo help
    vb sle
    Jan 2009
    adelaide
    Default diff and speedo help
    ok ive put a vl diff into my vb sle 3.45 ratio and the speedo is miles out can i just put a higher profile tyres on to compensate they are 205-65-r15 if i go to 215-75-r15 will this have much affect? has anyone fixed this problem or have a calculator so i can work it out also im gonna have to change diff as the 3.45 is not the best at 80kph it sits on 3000rpm so im gonna have to go 3.08 soon darn it
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Wink easy job
    Try your local diff or trans center they can give you a different drive gear for your speedo just sits under your speedo cable in your gear box .
    there is one 10mm bolt holding it in then you pull your cable out and it should be on the end or sitting in the gear box.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    yeah i think that speedo gear is a load of bull to be honest. i have tried a few shops and they dont know of any gears for my ratio. (3.55)
    unless you have ratio's that the car came with then there is no gear to make suit. i.e borg warner diff with *blah* ratio and turbo 400 fitted to a vb that only has *blah* ratio and trimatic will never match up.
    the only thing i have found is a thing called a 'ratio-box' sold by a guy in ballarat which is 200 miles from my house and he needs to keep the car...
    if you descover anything please let me know.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by leigh 7005 View Post
    I have a speedo gear chart on my site.
    Also I have a full range of M series gearbox speedo gears all in good condition.
    have a look at my site work out what you want and let me know
    cheers
    Scott
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by vkberlina View Post
    cheers
    Scott
    please tell me you have a gear for the 3.55 in my VK?
    pleasepleaseplease. i have asked sooo many places, no one has a clue.
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    If you cannot get the correct speedo drive gear for your gearbox then it is a simple as going to any reputable automotive instrument serviceman and getting them to make up a ratio box for your particular situation.
    muttley383
    ari666's Avatar
    1966 impala
    Mar 2009
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by ari666 View Post
    Yes I have a gear, i have in stock everything from 19 to 24 tooth gears.
    What gearbox have you got?
    What size wheels have you got?
    What size tyres have you got?
    what speedo gear have you got at the moment?
    either -
    what RPM are you doing at 100km/hr?
    how much is your speedo reading out by?
    I estimate without knowing the above you need approx 23tooth gear I have 3
    cheers
    Scott
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    23tooth gear pics per PM
    Attached Thumbnails Attached Thumbnails diff and speedo help-smimgp7090.jpg   diff and speedo help-smimgp7091.jpg   diff and speedo help-smimgp7092.jpg
  1. Diff gears/speedo change, it can be done by Holden
    By Troy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2009, 07:48 PM
  2. diff gears affecting speedo?
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2007, 06:39 PM
  3. Change Diff Ratio - Speedo???
    By REXMAN in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-05-2006, 10:42 PM
  4. Speedo Correction after diff Gear change
    By gtrboyy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 12:54 PM
  5. diff gears speedo recalibration
    By jdjones in forum V8 Development and Modification
    Last Post: 02-10-2005, 11:31 PM
