Hey guys
just got a VH SLX which is kickass, but the speedo is junk. The needle isnt stable at any speed and bounces around around with the car constantly. Any idea? i Thought the gears were stuffed but the fact it moves when the car bounces leeds me to belive the whatever the needle is connected to behind the dash
mine dose the same thing and the speedo cable had melted on the extractors but mines a v8 wats yours
your speedo cable is a square peg and if it goes in a round hole then itll bouch
capeesh?
lol, sorry will clarify my opinion. either you have not pushed the speedo cable all the way into the back of the speedo or the plasic square hole has worn a little bit round on either your speedo or trans drive gear. it bounces cos' the square edge of the cable only catches 3 out of 5 turns, whips your needle up to the correct speed then slips back to 0 again, over and over again.
check its all the way in the speedo, push that little metal locking tab down till it hits the cable and press it in like a mofo. if that fails... dunno.
