Results 1 to 7 of 7
Thread: vh ignition barrel
    vy executive s1 & vh sl
    May 2009
    newcastle
    Default vh ignition barrel
    hey does any1 have pics of what part i need to put on the barrel of my project vh.. i turn the key back and forth and the rod isnt connected to anything and not sure what i need.... ps how do u make a pic come up with ur name when you leave a post
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    did your barrel have a long piece of silver metal sticking out of it at the top?
    that bit needs to go over the little square piece of metal that locks your steering wheel. from memory to put it in you need to put the key in the barrel and turn it to 'accessories' which is between 'lock' and 'on' then slide it into the cylinder. there may be a small piece of plastic that pops in and out of the barrel when you turn the key to lock which you may have to press quite hard to push in as far as you can cos' that will foul on the cylinder when you try to slide it in and make the install impossible.
    its best to do this with the steering wheel off btw. its a bit of mucking around too. make sure you hve a beer or something nearby to calm down.
    p.s. the little pic is called an avatar and you will find the option to upload one in "user cp" which is a link at the top of this screen.
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by TUK20Z View Post
    I am asumming you mean The pastic cog that connects the back of the cylinder to the square part of the rod that sort of has teeth?
    Its either black or white cant remember, dont do many early model Commodores anymore.
    Or do you mean the end of the rod further down the column that conects to the actuall switch
    Daz
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
    May 2009
    newcastle
    yeah i mean the bit that the rod connects to cuz at the moment i have a rod that moves when i turn the key but its not connected to anything to give power to the car and unsure what i need as were trying to get the motor going but this has held us up
    1990 VN Executive
    Nov 2005
    Arh cool, I dont have a pic, but from memory its a oblong switch that bolts the column and the end L shape on the rod slides into.
    Pretty much the same, apart from maybe wiring from UC Torana to VL Commodore along with HQ to WB.
    Dazz
    Dynamic Locksmiths
    vb sle
    Jan 2009
    adelaide
    May 2009
    newcastle
    no thanks champ i sourced what i needed thanks mate
  1. vt ignition barrel
    By VT_R8ted in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2009, 03:31 PM
  2. ignition barrel
    By 235rwkw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2007, 07:26 PM
  3. Ignition Barrel
    By Vk_stock in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2007, 12:32 AM
  4. Ignition Barrel
    By ElDubya in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2006, 06:45 PM
