Results 1 to 7 of 7
Thread: location coolant sensor
    vk calais
    Dec 2008
    Default location coolant sensor
    gidday
    wanting to know the location of the coolant sensor 84 vk calais 5.o lt
    Ive been told it is not on the radiator.
    always getting lo coolant message and beeeeeeeeeeeep beeeeeeeeeeeep beeeeeeeeeeep
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Low coolant sensor is on the passengers side tank of the radiator its a 2 pin sensor careful undoing it you dont break the nut out of the radiator
    Coolant temp sensor is on the front of the motor above the water pump
    cheers
    Scott
    vk calais
    Dec 2008
    no sensor on left side of radiator there is a sensor on the right side wich Ive disconected and still beeeep bbbeeeeeep beeeee p
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Sorry my bad,
    LHS for a 6 RHS for the 8, try shorting the pins out as the sensor would go open circuit if no coolant, and closed for coolant. if no good check wiring, i have diagrams on my site. Else could be a dsh problem.
    cheers
    Scott
    vk calais
    Dec 2008
    Quote Originally Posted by vkberlina View Post
    Sorry my bad,
    cheers
    Scott
    love your website very helpful
    pretty shore its a dash problem
    Dont know if the beep beep beep speaker can be disconnected do you
    I dont want to destroy the dash but I'd love to disconnect that ####en beeper
    until I can get the dash sorted.
    I'm looking for a instrament technican on the central coast????
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    yeah Perfect Instruments PH 4392 4993 11 Cornwall Ave
    Gorokan NSW 2263
    If you need a replacement dash I have a working 6cyl dasht he tacho will just need to be set for an 8.
    cheers
    Scott
    vk calais
    Dec 2008
    Gorokan NSW 2263
    cheers
    Scott
    tried to contact him 2 weeks ago left a message no reply
    just tried to ring again same deal no answer
  1. IAT Sensor location
    By 93vr6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2008, 08:43 AM
  2. location of ECT sensor???
    By d_j in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2006, 04:19 PM
  3. iat sensor location
    By 9605wayne in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2006, 05:35 PM
  4. IAT Sensor Location
    By S Pack in forum Electrical Wiring / Questions
    Last Post: 10-10-2005, 04:32 PM
  5. IAT Sensor Location
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2005, 08:27 AM
