Results 1 to 7 of 7
Thread: Vk Black 202 Questions
    Vk Sl
    May 2009
    Default Vk Black 202 Questions
    Hey Guyz, My plans of a 308 went down he Drain so now i'm doing a 202 5speed
    The only Problems i have is.. Tailshaft, I got a Tailshaft with the 5speed but the Diff end doesnt Bolt up.. Is there someway of Moding the 4speed tailshaft to suit the 5speed in the output shaft?
    Dizzy, i was looking at the dizzy thred and i was going to do the VH Blue 202 dizy but i went to about 6 wreakers 2day and they are like gold.. cant even find a Normal Black Dizy So if anyone can help me out with one that would be Heeps good
    Also, sorry to be a pain but Strater Motors, is there any difference Between Auto, Manual4speeds and 5speeds??
    well if you can lend me a hand with these questions i would be very greatfull thanx.
    Cameron
    jakbob's Avatar
    jakbob is offline Lighten up.
    VX SS, VC L, VK Vacationer
    Dec 2008
    You might be able use the front half of one tail shaft and the rear half of the other. Try ebay for a dizzy, you should be able to get one under $100. I believe the starter motors are the same for all boxes, I think it was just the later v8's that had different starters for different boxes.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    You can use a VK EFI Dissy, there suppose to have a smoother curve anyway.
    Get a bosch starter, they are smaller and fit alot easier.
    As said you can swap the two halves (make sure its the correct length), there were two diff's used, salisbury and borg warner,
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Vk Sl
    May 2009
    Thanx for the help guyz, i have a Dissy on its way and Changeing the Tail shaft in a few days... Question about the Starter motors there all the same yeah? Auto, 4speed man, 5speed Man??
    cheers Cam
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by VKcambo View Post
    cheers Cam
    Yep
    Vk Sl
    May 2009
    Thanx heeps. Once i get the Clutch on thursday-friday the motor is going in and its almost time to go off to paint. Black with Twotone Gunmetal Gray with silver septors. Does anyone no if you can get the Motor and box bolted up in at the same time?
    Cheers Cam
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Engine and gearbox can go in bolted up at the same time. Remove the engine fan first, also helps if you remove the radiator and bonnet to give you more room.
  1. [VIC] 4x Black Interceptors with Black Center Caps
    By Hardstylin in forum Parts And Other Items For Sale
    Last Post: 28-05-2009, 07:27 AM
  2. Replies: 73
    Last Post: 04-02-2009, 04:54 PM
  3. black carby or black efi
    By john_mete in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-01-2009, 12:13 AM
  4. 202 black - varajet, webber, holley or efi + other questions
    By TheWombatDriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-04-2006, 04:11 PM
