Results 1 to 7 of 7
Thread: Auto jumping out of gear on corners
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    Default Auto jumping out of gear on corners
    Gurus,
    Not long had my 1983 VH 202 auto and i've noticed that sometimes, going around corners (mostly left) the gearbox will momentarily slip out of gear then back in again. As far as I know the car hasn't been in any accidents and the selector isn't moving or slipping around the corners. It just feels and sounds like it's momentarily slipping into neutral then back into gear with a little chirp of the tires, a reasonable jolt in the back end and a little stain on the seat covers (only the first time though).
    I'm not flogging it around corners, particularly now, and this car is destined to be my daily driver.
    Has anyone else heard of this before? Any valves / pressure sensors likely to be affected by lateral G's? Obviously it'll end up at a transmission place but I wouldn't mind learning about it a little more first.
    Thanks,
    Lewie.
    faroogoo's Avatar
    faroogoo is offline SENTINEL
    GMH
    Nov 2006
    S.A
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    Quote Originally Posted by faroogoo View Post
    Oil level on the mark?
    Looks like it. It was warm when I checked it but on the mark.
    308 VH
    Aug 2008
    Would definately put my money on low oil had a VH do the same thing. Have you checked the oil at running temp/ level ground/and engine running at idle.
    If its only doing on corners the oil is swishing to one side away from pick up in sump causing it to loose drive.
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    Quote Originally Posted by projectvh View Post
    I'll add it to tomorrows list of things to fix. I'll post my results to. Thanks ProjectVH.
    vb sle
    Jan 2009
    adelaide
    its the plenatry gear the gear box is stuffed its a common problem or its your gearbox or engine mounts
    my vh did this and it ended up beeing the engine mounts but my dads a mechanic and he said most likly the plenatry gear in the gear box
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    Thanks for the replies gurus. The oil was a bit low so I topped it up and took her for a spin. I only went around the block but it seems to have sorted the issue. Even managed to get a bit of wheel spin on one corner but it was wet, and it was just one wheel.
    If the problem persists (please see your doctor) I'll investigate the gearbox internals and I'll check the mounts.
    THANKS!!
  1. vx ss auto no 2nd gear
    By blockhanson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2011, 01:29 PM
  2. One Owner 4spd VB 2850 jumping out of 4th gear
    By Rogera in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2009, 05:54 AM
  3. VS Auto: no 4th gear???
    By vshilux in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2008, 10:17 PM
  4. auto gear nob
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2007, 07:13 PM
  5. Which gear to tow in? VR 6 auto.
    By nomad in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2006, 02:28 PM
