Results 1 to 12 of 12
Thread: vk speedo out
    L67 vt series 2 calais
    Oct 2008
    Default vk speedo out
    Hello everyone i have recently bought a 4spd vk but i put 205/65's on and i think it might be throwing the speedo can anyone help with ficing or correcting it without changing tyres?
    and can you get digital spedo's ?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    You need to change the speedo drive gear in the box, first work out what percentage its out, and what colour gear you have now. Also theres a drive and driven gear (i get the two mixed up, but a guru will want to know both, sorry but Im not a guru with this shit, I just play with speedo gears till it works )
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VK Berlina 308
    Oct 2005
    eastern melbourne
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    Quote Originally Posted by oOSparkyOo View Post
    haha in my VH i dont have the original gear box and i dont know what gear box it is and my speedo is out by 20kmph there is a place around my area that fixes em but if its easy i i do it my self
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by trepaul View Post
    205/65/15 is about 3.3% out, based on stock size of 205/60/15
    If thats the case, then swapping the drive gear wont fix it, each tooth is equivelent to 5 or 10km/h, so it would bne the drive in the gearbox need replacing to be 100% accurate.
    Quote Originally Posted by budgieVH View Post
    20km/h is alot easier to fix, check with a GPS if you can, and get a percentage figure.
    Once you have the right gear, you just undo 1 bolt, pull the cable out hard, whilst tearing your hand apart on the gearbox cross member, jump in pain and smack your head on the exhaust, so swear some more and throw your ratchet, which bounces and smacks your kneecap..... once its out, put the drive gear off, fit new one, clean the blood up, and push back in and put the bolt in. About a 2 minute job, wounds may take a few weeks
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    If anyone is chasing gears I have a full range of commodore speedo gears & info on my site to work out what gear you need.
    cheers
    Scott
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by vkberlina View Post
    cheers
    Scott
    Scott, not sure if you want to add this to your site, but a M76 with a yellow drive gear (10 teeth), needs a white (20 teeth) driven gear, when used with a 3:08 diff. I dont think its a factory combination, but this information doesnt seem to be on the net anywhere when I searched for hours. The above combination was also 100% accurate with a GPS.
    [EDIT] With 205/65/15"
    Oct 2008
    thanks for tips ill check out what gear is in it and i went side by side with somone and its out by 10-30 khm from 50k's 60k's 80'ks might need a new speedo cable aswell
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Try and do it at 100km/h with a GPS.... get Speedos speed when GPS says 100km/h. and what the GPS says when your car says 100km/h.
    GPS, is more accurate, also your not relieing on a person maintaining speed, or there speedo being accurate.
    Vh driver is offline Holden Australian Pride
    vh sl/x
    Jun 2009
    Hay guys im new to the forums and drive a 1983 vh, i have had this issue from the day i got it and have found out with gps and driving around that my speedo is out by 10 kph exactly from 50 kph on wards sitting at 50 is fine and at 110 kph is fine but between that its 10 out what would be the best way to fix this issue.
    Thanks for your time guys
    Matthew
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Vh driver View Post
    Matthew
    It should be a consistant % out. Being accurate at a higher speed but not a lower speed isnt right. Either your speedo, or the drive cable is shagged I would say.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    woo hoo! a use for my how to guide
    how to give your stock air cleaner a better note
    its not like cutting random ugly holes. you will never know looking from the top
  1. speedo
    By clarmatt in forum Electrical Wiring / Questions
    Last Post: 02-01-2009, 08:47 AM
  2. speedo on vs
    By p_schrapel in forum V6 Development And Modification
    Last Post: 26-11-2008, 07:08 PM
  3. Speedo
    By CHANDLC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 11:06 AM
  4. speedo off??
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2005, 04:51 PM
  5. speedo
    By Stretchomatic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2005, 05:16 PM
