buyin some 20s off a mate, wonderin if they'll fit on the car with it at stock height?
cheers..
20s what??
20" rims will fit but you might not get rubber on them how wide are they what rubber is on them?
not sure how wide they are.. i know these tyres are on them hope you can help!
Potenza 245/35/20
Stock Tire - 205/60R15 >Search Tires Tire 1 - 245/35R20 >Search Tires
Section Width: 8.07 in 205 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 15 in 381 mm
Rim Diameter: 20 in 508 mm
Rim Width Range: 5.5 - 8 in
Rim Width Range: 8 - 9.5 in
Overall Diameter: 24.68 in 626.87 mm
Overall Diameter: 26.75 in 679.45 mm
Sidewall Height: 4.84 in 122.93 mm
Sidewall Height: 3.37 in 85.598 mm
Radius: 12.34 in 313.43 mm
Radius: 13.37 in 339.59 mm
Circumference: 77.53 in 1969.2 mm
Circumference: 84.03 in 2134.3 mm
Revs per Mile: 842.7
Revs per Mile: 777.5
Actual Speed: 60 mph 100 km/h
Speedometer1: 55.3 mph 92.2 km/h
Speedometer Difference: - Speedometer Difference: 8.385% too slow
Diameter Difference: - Diameter Difference: 7.74%
Wrong size for the car they might fit bit you wont get full lock on steering and your rears will prob scrub the wheel arch.
cheers
scott
hmmmmmm :/ has anyone put 20s on their vk?
depends on the shocks too, they have the little lip that flares out at the top to stop rocks getting into the bottom of the bearing. that stopped me fitting 17's with tall (65) rubber. lower profile i dont think would have made a massive difference...
its not a prob for everyone, but be wary of it.
Need some parts for my VH 253:
Green standard steering wheel...Green lower B-pillar covers.
Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
PM with any info.
2 words mate..... good luck
I am currently fitting 20s to my vh running a 225/35/20 tyre. At the front I am going to run a koni adjustable shock with compressed springs + guard rolling and the strut platform is getting cut and re welded 3" higher to allow for clearance of the front tyres. And the rear will hopfully only need guard rolling and compressed springs!
At stock high and susspention you will need a tyre size of 225/30/20 but insurance will hate you
I wanna know if 19" vy signatures will go onto my VK calais with no problems?
if you run 245/35/19 tyres on the signature they will as my sigs with that size tyres fit straight on my calais. for 20s you would need 30 profile or even 25 id imagina to not hit the bottom strut plate
yes 19's will
and as above for 20's not 25 profile though 30 will fit you wont find a 25 profile in that size that is legal
ive got 4 225/35/20's ill take 350 for the lot there like new
Had 20s on my vk 20x8.5 35mm offset and 235/30/20 tyres didnt rubb also had them on my old vk and never rubbed on that either. Have put them back on my VR Senator for now.
HSV802 VR Senator 185i Manual.
Rides : 2002 VX HSV Clubsport
1987 VL Commodore 5.0L
i must be gettin old or something cos' 20" tyres just make think 2 words...
dick
head
i got 20" FR simmons, 245 on my vk. gaurds rolled all round and front and rear k sport coilovers. only scrub at full lock in reverse. its on it guts too.
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
The simmons sound sexy, however this thread is way old and since then did decide not to put 20s on the car. I ended up putting 19inch signatures which looked great, but since have put polished vk calais rims on it. You should post a pic @OFF T4P
