Results 1 to 2 of 2
Thread: VH Dash switches
    VY executive ute s1
    Jan 2009
    Default VH Dash switches
    hey guys, neone got ne ideas on what the switch with the ariel/umbrella like thing is for? i it for the ariel? It does nothing when i press it lol
    VK SL EFI/ Monaro CV8
    Sep 2005
    If the switch has a symbol that looks like a "tree", then it is the power antenna up and down switch. If the car had a factory fitted antenna then this switch is wired to the antenna via a black module box, which controls the power to the antenna. This box is fitted just above the left hand side kick panel, just inside the dash next to the left hand vent duct. If the module is working you will hear a faint click noise when you have accessories power on an you press the switch. For the antenna to work, it must be compatible with the module (if factory fitted) and is wired correctly via the switch and factory wiring loom. Sorry if I have given too much information.
  1. VQ SII switches
    By GMBanisher in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 05:42 PM
  2. Dash Wiring & Dash Switches
    By JoshSvc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-03-2009, 01:59 PM
  3. Replies: 18
    Last Post: 03-11-2008, 04:12 PM
  4. Switches Behind Power Window Switches
    By extremeaudiowa in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-05-2007, 10:38 AM
  5. switches
    By naf33n in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-10-2006, 05:39 PM
