+ Reply to Thread
Results 1 to 8 of 8
Thread: Where are my heater hoses?
    Lewie's Avatar
    Lewie is offline B Cast and flat topped! Lewie Executive
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    Default Where are my heater hoses?
    Gurus,
    I'm sick of driving to work freezing from the cold air blowing on me through the gap in my drivers window seals and the cold air I get through my heater when I turn it on.
    I have two empty looking stumps poking out through my fire wall which I suspect are for my heater. See pics. If they are infact my heater hoses where do they go? I have an idea but I'd like someone else to confirm this first. There are two hoses at the fromt of my block below either side of my thermostat housing that loop back into the engine quite sharply. I'm not sure if they have been blanked off or not. Do the heater hoses go in there? If so top of bottom.
    I have an absolutly crap scan of a workshop manual but the pictures are too blury to see anything in detail. Another (book) on the way though.
    If someone has the know-how to add a pic of where they are supposed to go that would help but any help would be appreciated.
    Attached Thumbnails Attached Thumbnails Where are my heater hoses?-26062009123a.jpg   Where are my heater hoses?-26062009125a.jpg
    vb sle
    Jan 2009
    adelaide
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    But both sides are bent over. Does one stay there and the other bent hose is replaced by two heater hoses? If so which side?
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The two outlets on the drivers side go to the heater, the ones on the passenger side go to the inlet manifold. Some inlet manifolds are water heated. It doesn't matter which one goes where to the heater core, it will still flow.
    http://www.facebook.com/?ref=home#!/...21292461287296
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    VR Commodore
    Apr 2009
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    That had crossed my mind. I'll investigate this a little more. What would be the worst that could happen? Boiling coolant over my feet?
    Vh driver is offline Holden Australian Pride Vh driver Executive
    vh sl/x
    Jun 2009
    yer just hook the garden hose up first maby at least that is clean water not coolant, you could get lucky it could just be something like one of the hose bust and the last owner was to lasy to replace it lol
    if not then yes hot coolant over your feet lol
+ Reply to Thread
  1. VS Heater Tap Hoses
    By Mickyh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2008, 06:17 AM
  2. Leak from heater hoses or valve??
    By BobEddie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2008, 06:39 AM
  3. New heater hoses now no heat?
    By fergies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 03:16 AM
  4. Vac hoses for heater system
    By dixie265 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2007, 07:28 PM
  5. Best way to remove heater hoses at firewall
    By commodore2004 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-08-2006, 04:42 PM
