+ Reply to Thread
Results 1 to 2 of 2
Thread: GEN III Conversion INFO Needed!
    crashy13's Avatar
    crashy13 is offline =(BUSTOUT)= crashy13 Executive
    VX SS II 9C1 & VH SL/E
    Aug 2005
    Default GEN III Conversion INFO Needed!
    Im trying to find anything about putting a gen 3 into my vh, i have everything to do it i just want to know if anyone has info or know where some is? cheers
    VX 383 turbo & VK Royale LS1
    Apr 2009
    South Auckland
    There are kits available from CRS , Mel Woods etc.
    I'm doing a VK, main stumbling block is relocating the starter to the pasenger side of the engine, just not enough room for steering, starter and exhaust on the drivers side.
    We have a local who has just put together a starter relocation kit, useing a jap diesel starter with a reduction drive to suit the LS1 and a bolt on mounting bracket, (no sandwitch plate or welding lugs on block) for $550 so will be going with that.
    I am useing a VN V6 crossmember and steering rack (straight bolt in) gives more space for drivers side header and sump. Will be useing V6 mounts and will make my own brackets from Block to engine mounts.
    Headers are the hard part, not much room to squeeze them in, I will prob take a set of headers and chop them round to fit, may look at 5 ltr headers and just chop the flanges and weld on LS1 flanges (port spaceing is identical) or maybe even chop some VE HSV headers, they look to be a shorty design which could be adaptable.
    Gearbox mount should't be too hard to knock up, driveshaft will need to be shortened.
    I will be going auto so no clutch hydraulics to worry bout.
    The other costly part is sorting the instruments, speedo in particular, either a elecronic to manual speedo adaptor or swap cluster to electronic speedo, revcounter etc.
    Fuel system- will be putting a VN fuel tank in(again just a boltin) with an intank Walbro pump and an external fuel pressure regulator.
    Radiator - not sure yet ! either a VK V8 which has similar layout to VT-VY or there are some VK to chev radiators available with outlets similar to VZ, which will allow battery to stay put intake and air filter on drivers side.
+ Reply to Thread
  1. VL rear disc conversion info needed
    By abcent in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-03-2009, 12:56 AM
  2. speedo info needed
    By Budz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-09-2008, 06:49 PM
  3. vs non irs suspension info needed!
    By gee38l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2007, 02:35 PM
  4. info needed?
    By bpw87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2006, 06:57 PM
  5. exhaust info needed plz!
    By Jazack in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2005, 03:46 PM
