+ Reply to Thread
Results 1 to 7 of 7
Thread: lpg 50lt calais
    vk calais
    Dec 2008
    Default lpg 50lt calais
    Does anyone run their pride on gas ?
    Ive had mine converrted and run the flashlube kit.
    car seems to like the gas (runs smooth)
    Starts better in the morning
    Not quote as crisp off he line but otherwise Alls good
    ari666's Avatar
    ari666 is offline celebrate disrepair ari666 W427 ari666 W427 ari666 W427 ari666 W427
    1966 impala
    Mar 2009
    mine was on gas. i took it off. hate gas. dont care that it is cheaper. i enjoy boot space. lpg tanks take up valuable woofer room. along with a bunch of other annoying things.
    if its a quaddy be prepared to replace the gaskets, accelerator pump diaphram and secondary hanger cam every so often as they melt.
    other than that i have heard a bunch of power can be made on gas because it has the ability to run on a 12.5;1 comp ratio without pinging. which would be fun.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake! DANNY8 Caprice
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Runnin me bro's GQ on gas. It runs waaay better on gas then petrol, even accelerates harder. Got the tank underneath so ya don't loose any boot space.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face Paiste402 Berlina
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Ive driven a 5.0 on gas and petrol, didnt actually notice any difference at all. I had to check the LPG gauge to make sure which fuel i was using! I had my mild 308 (cam, bore, flat tops) on LPG. Didnt like it on that, the LPG was set up for dual fuel and leaned out too easy in high power situations. Also mainly cause the gas wasnt tuned accurately and needed a service hahaha.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by DANNY8 View Post
    heh. try and put one under a vk calais...
    ok, so one example would be this; i had 6's (spark plugs) in my beast cos' it was on gas. anyway i forgot that they were 6's and carried on modifying the rest of the engine. i failed hopelessly on a dyno and in my re-doing things, went and replaced my 15 dollars each NGK iridium 6's with 2 dollars each ngk copper 5's and the car rans HEAPS better.
    ya just cant tune for gas AND fuel. its one or the other.
    sorry not trying to start a thread war.
    love
    the lightning
    Jun 2005
    under the Southern Cross
    piss the dual fuel set up off and run an impco 425 on a Holley 650 throttleplate... you'll love it over a dual fuel set up anyday... only drawback is it leans out after 5000rpm
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
    Miscellaneous
    Jul 2009
    the Netherlands
    Mine runs on gas too, 80 ltr tank as far back in the boot as possible feeding a varajet 2 carb, i don,t care about boot space..if i need to take some stuff around i rather take my Olds full size wagon (also gas,under the floor).
    Only i put in some Bosch super 4 plugs..they have 4 electrodes around the center one ,so there is a open spark making starting easy and picking up engine speed at low ref,s a lot better.
    Further i set ignition timing some degrees more advanced than standard, on high octane fuel it start,s pinging on heavy load now..but on gas it,s perfect!, also enriched idle mixture somewhat..i drives great , does 800 km on one tank..
    Fuel does great for me...for cleaning engine parts...and for making a fire in my gardenstove..
+ Reply to Thread
  1. [SA] vx calais altezza monaro lights and vt/vx calais doors
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 24-04-2009, 12:33 PM
  2. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
  3. Replies: 57
    Last Post: 12-10-2006, 07:47 AM
  4. WTB: stock VK calais / VL calais headunit
    By DaRiO in forum Swap / Wanted to Buy / Trade
    Last Post: 16-05-2006, 10:03 PM
