My dad just put new disc brakes on his VH Commodore and now there's a wierd shhhhing sound coming from the bonnet, i think its the Brake Booster but im not sure.
Any know what it is and how to fix it?
Thanks for any and all help.
check the condition of the vaccum lines leading to the brake booster mate
will do, heres a liitle more info i probably should have included in the OP the noise only occurs when braking.
probably not the answer but di you put that anti squeel goo on the back of the pads?
when you say shiiing, do you mean like a metal sound? like when knights take their swords out o sheaths in movies? or like gas escaping?
If it's your Brake Booster, then your pedal will be heaps harder to operate.
Just replaced mine twice in a VK carby 6, biatch of a job!!!
1st one was a VK dual-diaphram V8 unit, but only one diaphram was good. Had boost, but still had "wooshing" noise.
2nd was from a VL and works perfectly.
I can't see how changing pads would upset the Booster, but stranger things have happened!
When you say he put new disc brakes on, what did he actually replace?
so a vl one fits in vb vc vh and vk will it fit with a v8 ?
