Results 1 to 13 of 13
Thread: carbie problem???
    VN V6 Executive Sedan
    Nov 2008
    Default carbie problem???
    I have a vc commodore, varajet II carbie, 3.3 blue motor and a new fuel pump. The carbie has just been reconditioned too. if left for 3 or 4 days, the engine cranks but won't start. it's like there isn't any fuel in the carbie. but then when the carbie gets fuel in it then it will start. does anyone have any suggestions, help or advice that would maybe help me out???? Thanks.
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by viccib View Post
    Almost like my problem (my car still will not start). Have you checked it for spark?
    Nov 2008
    it's only first thing after a couple of days. there is plenty of spark, new spark plugs so no problem there. any other time, it starts fine. thanks.
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    Cracked or blocked fuel filter or lines? Could it be sucking air from anywhere?
    Nov 2008
    new fuel filter, will check the lines tomorrow. will also check if there is an air leak anywhere. do you think it could be the stop solenoid on the carbie? could that be getting stuck?
    The Blues Mobile
    Dec 2008
    Western Sydney
    Also someone sugested to me to try putting some fuel down the carby (a little bit) to see if it runs from that.
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by Cheboorator View Post
    thatd be the best way to see if its loosing fue out of the bowll somehow..
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    A carby guru told me to check the solenoid by removing the wire from it, turn on the ignition and then touch the wire to the terminal. You should be able to hear an audible clunking/clicking sound as you do this.
    Worked for me.
    Nov 2008
    hubby changed the solenoid on tuesday, and it worked better this morning. will try to start again in a few days to see if this fixed the problem. will let you guys know what happens. thanks again everyone.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the solinoid only blocks the idle jet to stop running on when you turn the key off.the petrol will just be evaporating away especially when stopped hot then left a few days takes a few turns of the crank for the pump to fill the bowl again before it will start.also check the 2 dranin screws under the carby bowl they may be weaping fuel
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Nov 2008
    hey guys, all i can say is that hubby swapped the idle stop solenoid and it seems to have fixed the problem. went to start the car today and the fuel was still in the carby and started on the first go. not bad hey??? thanks for all suggestions they were really helpful. if someone has the same problem, can you try suggesting this solution?? anyway, thanks again.
    Nov 2008
    an update!!! hubby started the car again today and it started first go. I think we have finally fixed the problem. the old solenoid was sticking and it seems that by replacing it has fixed the problem. once again, thanks for all help and suggestions.
  1. 202 black carbie
    By oxmate in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-10-2008, 06:41 PM
  2. Electronic fuel pump for Carbie
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-04-2007, 06:59 PM
  3. Carbie on standard blue 202
    By cannibal in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-12-2006, 12:06 AM
  4. Vh 308 carbie options?
    By bertusmcspurtus in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-11-2006, 04:37 PM
  5. need pics of carbie set-up help
    By bellie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2006, 08:11 PM
