Results 1 to 10 of 10
Thread: VH 253 Fuel Additive?
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    Default VH 253 Fuel Additive?
    OK firstly, welcome back to me as i have a commy again ! Just bought a VH, has a 253 in it, am unsure whether to run a fuel additive in it ? The bloke i bought it off said the original owner told him he didnt need to, then he proceeded to tell me that holden red motors are built tough adn shouldnt need it ! hahhahah I think he confusing it with a VB commodore, re the red motor. IS it ok to put additive in just to be on the safe side? or will crap build up in my engine?
    vb sle
    Jan 2009
    adelaide
    dosnt matter if you use it or not i recon its a scam to use more money on somthing you dont need just like anty slip for trans and stuff that crap dont work ive never used it and never will and my cars fine
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Can someone confirm this? I'd still put additives in, since it was not designed to run unleaded.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    I run additive in the HJ which has a 253 just to be on the safe side because these cars well and truley pre date unleaded petrol
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    depends on what type of additive you are talkin' about.
    personally, with the money i saved from not buying the additive, i would whip the head off and send it to get unleaded seats.
    job done.
    The Blues Mobile
    Dec 2008
    Western Sydney
    What if you put that 98 octain stuff in? i remember there was a thread somewhere here about the best fuel for the car, some people suggested to run it with the 98 stuff.
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah its more about what the additives in non-leaded fuel does to your seats. some ppl think that it has to do with heat but i heard on the grapevine that it is more the fact that the 'lead' is no longer being thumped into the seat each time the valve shuts that does that damage. dries it out or something.
    seriously, how much is it to get seats done? and how much is each pill? or bottle? try grabbing some old heads from the wrecker, have some fun cleaning up the ports/chambers etc with your die grinder, then send it off to get new seats. i paid 800 for the full reco+ bigger valves+supply valves+new k lines+decked
    worth every penny
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I have posted this several times before
    Now reasons for running correct octane fuel...
    When you run a low or insufficient octane fuel, your engine pinks (detonates, pinking, pings, knock what ever you get the point.) Under load.
    Now this causes huge increases of heat in the combustion chamber. Now what this does is causes your exhaust valves to get to point where they begin to melt on the surface. Now generally under high load and/or high-RPM this can/will cause engines to fail.
    Now you don’t _have_ to run lead or an upper cylinder lubricant. Under normal every day driving conditions your exhaust valves wont get hot enough (using fuel of sufficient octane) to cause valve seat recession. Even under higher load scenarios this will mostly be the case as well.
    I Oz we have had fuels with 98 octane like Shell V-Power and the mobil, BP & Catel Vortex 98 these generally exceed the octane rating for most cars. As you have sufficient octane the car wont pink, because it isn’t pinking you have lower combustion temps so your valves don’t get as hot. As they are not getting, as the valves don’t micro/localise weld themselves to the seats so you don’t get valve seat recession.
    note Regular unleaded is around 94 from memory & premium is 96 along with caltex vortex which basically is premium with injector cleaner. V Power, Vortex 98 and the other flavours by mobil & BP are all 98 octane fuels.
    If you drive an older car like a VB-VK and it is driven in a low-stress application, basically used as a daily driver, then you need have no real need to run upper cylinder lubes or lead. As long as you use a fuel that meets or exceeds the octane rating for your engine. Really the only time you hay require an upper cyl lube is high sustained loads and RPM all the time.
    If you rebuild your engine the best way to overcome this from ever happening is to install hardened exhaust valve seat inserts and exhaust valves of harder materials, such as 4N stainless.
    Also if you lower your compression this will enable you to run a lower octane fuel. Simply retarding your timing isn’t really the proper way to tune an engine to run a lower octane fuel. Although you can advance your timing when you run a higher octane fuel this is because the cars timing was retarded from factory to pass emissions laws etc.
    If your car pinks for a longer period of time you may experience pre-ignition or overrun when you turn your engine off. Basically what’s happening is your cylinder is so hot it’s igniting the fuel without the need for spark. This generally wont last long as your engine will destroy itself pretty quick.
    The early commodore engine were designed for 97 octane super. If you run 98 octane fuel you wont need to run an upper cylinder lube. Super used to contain approx .14grams per litre of lead, Potassium, Manganese, Sodium & Phosphorus based upper cylinder lubes wont do the same job as leaded fuels, they burn at a lower temperature than lead does. Although they may aid in protecting they wont do the job as well. Sodium based substitues have been linked to damage to turbo charges.
    Most additives will also contain a octane booster component. The higher the octane fuel the cooler the compustion temperature will be.
    cya
    Scott
    The Blues Mobile
    Dec 2008
    Western Sydney
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah what he said....
    i knew all that... i just... worded it... sorta differently :P
    lol.
  1. Diff Additive ?
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-07-2009, 08:01 AM
  2. New performance additive!
    By Hunter SS in forum The Pub
    Last Post: 11-07-2009, 08:58 PM
  3. Injector cleaner additive for super6
    By whstatesman2000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2009, 04:15 PM
  4. engine additive
    By vr-man in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2008, 10:38 PM
  5. LRP no longer sold....some additive questions
    By Chode in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-01-2005, 11:05 PM
