Gday all. I have a quick question for you all. I would like to put the vk bumpers bars on my vh. How does the front bumper bar go on? Do i have to change the brackets on the front bumper bar? To make it sit right? Also do I have to change the guards as well. I've already done the back end, its just the front. HELP PLS!!! Cheers Jason.
MISSING
WIFE AND DOG
REWARD FOR DOG!!
You need to cut out part of the front apron & fit vk bar brackets, front guards are the same
Why would you want to do that? The Chrome steel bars are what makes the VH stand out.
Have you thought about buying a VK?
thanks for that mate, do you have any ideal how to bolt them in? The vk has nuts welded to the frame, should do the same.........cheers Jason
MISSING
WIFE AND DOG
REWARD FOR DOG!!
if you were in darwin i'd swap with you. i want chrome.
ECOTEC KICKED IN yO!!!!!!
u just half to cut a bit out of the front apron so the vk bracket wil fit in and it wil bolt stright in
Thanks for your help guys. DRAD-81, G'day, the vh i just want to change the look, and mate i do own a vk. My vk has efi v8 with group a kit on it. in the future i might put a vk bodykit on the vh. Cheers Jason
MISSING
WIFE AND DOG
REWARD FOR DOG!!
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
is that it??? i though guards bonnet etc had to be changed too?? cos there is a nice VH with an intact front at the wreckers atm
edit* what about the rear bar?
The VH's have chrome mouldings under the headlights, but they are interchangable between VH and VK as both headlights are identical. Don't have to change any of the panels.
The rear bar I think just needed to redrill the holes as they aren't in the same spot, or make a small bracket (just a bit of flat bar) drill a hole in each end, bolt one end to the bumper, other end to the original VK bumper holes.
But yeah it's straight forward, don't need to change any panels.....just have to cut the apron up a bit if ur putting VK bumpers on a VB-VH, but the bumper covers it all. No cutting required if putting VH bumpers on a VK.
If ya do put VH bumpers on ya VK, ya have a big hole under it coz the aprons are different. Just check out the front of my wagz and you'll see the big mouth lol.
