Results 1 to 21 of 21
Thread: single black wire to trimatic
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Default single black wire to trimatic
    i cant find my frikken commodore manual anywhere
    anyways, anyone know what the single balck wire does that goes to a V8 trimatic? the plug is loose and the little pin it clips onto pushes into the box. i had to get my pliers out twice to get it out.
    wondering if it is absolutely necessary or just some stupid dash warning light.
    p.s. my reverse lights work fine as does the neutral safety lock with it off.
    cheers
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    Kick down wire.. Its connected to your Accelerator pedal..
    Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    high speed kick down, as opposed to the vacuume kickdown which occurs automatically. When you floor ir, the pedal pushes a switch which activates a solenoid through that wire.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its called the full throttle detent valve if i remember right might help you find some info.should be a slide switch for it on the throttle pedal too thats where the wire comes from
    ari666's Avatar
    1966 impala
    Mar 2009
    you guys rock! cheers
    also a quick one... if i stick my finger in the hole where to speedo gear should be, should i feel any teeth of the gear it connects to? all i can feel is a smooth shaft (giggity) speedo stopped working a time back and i am now trying to suss out why.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the plastic cog might have snapped in half and fallen off the shaft
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah thats what i am thinkin how hard is that replace? does it mean dropping the trans and taking the end off it? i suck at transmissions.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    haha not hard to slide the rear housing off and put a new one on
    ari666's Avatar
    1966 impala
    Mar 2009
    ok, diggin up old threads, but CBF making a new one.
    is there any way of tweaking the trmatic so it drops down gears more regularly. i have low vac (due to cam shaft), stall converter and shift kit and i am sure that one of those things is messing with my down-shifting.
    i have to do it manually and my girlfriend alsways gets that "oh my god your about to kill me" look whenever my hand goes anywhere near the t-bar, so i want it to happend by its self.
    cheers
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is the slider on the accelerater pedal for the detent adjusted right
    ari666's Avatar
    1966 impala
    Mar 2009
    в∞ѕтεכ √&
    Jul 2008
    NZ
    oh no dont make me get my vk manual out i only just buried it in the bottom of the cupboard LOL there is a detailed setup procedure in the manual for it if i remember rightly silly things like adjusting the accelerater cable make it get out of whack
    ari666's Avatar
    1966 impala
    Mar 2009
    в∞ѕтεכ √&
    Jul 2008
    NZ
    wouldnt be much difference to the quaddy in pull radius ide amagine
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    well after laying in that position, (you know the one, feet on the ground, back in an arch with the seat digging right into your spine staring up underneath the dash?) for a while, i figured it out. thanks delcowiz, its all in the accelerator pedal, i never really took much time to study the pedal itself, but its pretty stupid.
    anyways, its in the cable, you're right. i had to wind out all the way in the engine bay, reset the starting point of the pedal and then get in and out of the most painful position a human can take, to get it spot on because if you have too much cable the switch stops any further acceleration, and too little doesnt switch it over.
    in fact i actually got a little more opening out of my secondarys cos' i wasnt aware there was any adjustment on the pedal itself, thought it was all in the engine bay.
    very good afternoons work, im off to have a beer now
  16. #16
    в∞ѕтεכ √&
    Jul 2008
    NZ
    haha so did it help the problem too haha maybe we got you that extra 20kw you wanted from the secondaries opening fully
  17. #17
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by delcowizzid View Post
    it did help, totally changes the way the car operates now if you put your foot down. b4 was like... foot flat, wait... wait ...wait ...then it drops to second once the vac kick down engaged, now it kicks to first straight away. its a bit dangerous actually, might have to take it a bit easy on the pedal.
    but no to the 20KWs sadly, cos i have since replaced the 750 Vac secondarys (it went on the dyno with) with my old 650 double pumper and 1 inch spacer. the spacer was the thing messing with it, cos' the carby sits higher and the cable had to go 'up' slightly it needed more free play to get it around the last little bit of 'curve' if that makes sense.
    but yeah, anyone reading this check your little slidy-switch thing, although it hurts to look at and adjust, when its setup right it helps heaps.
  18. #18
    в∞ѕтεכ √&
    Jul 2008
    NZ
    maybe its a little too adjusted ya misses is probably gonna wish you were grabbing for the stick now LOL
  19. #19
    ari666's Avatar
    1966 impala
    Mar 2009
    BAM!!! no warnings that s what i like to see.
    sadly, i have had too many beers today to drive home, so its her that gets to test drive lol, i am not gonna tell her i have played with it and see how well she can turn into a skid under power
  20. #20
    в∞ѕтεכ √&
    Jul 2008
    NZ
    hahaha oh yeah sorry love i messed with it a little
  21. #21
    ari666's Avatar
    1966 impala
    Mar 2009
    YOU KNOW IT!!! you know the comment you have to make!!! ill bet youve said it once or twice yourself whilst trying not to piss yourself laughing.
  1. Replies: 73
    Last Post: 04-02-2009, 04:54 PM
  2. 1 wire or 2 wire O2 Sensor
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2009, 10:05 PM
  3. 6 cyl trimatic tailshaft will it a V8 trimatic
    By SL/E 4 ME in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-04-2008, 07:07 AM
  4. 6cyl trimatic tailshaft into V8 trimatic
    By SL/E 4 ME in forum VB - VC - VH - VK
    Last Post: 12-03-2008, 08:17 PM
  5. black wire runnning along RCA's???
    By semi in forum Car Audio
    Last Post: 09-10-2005, 11:07 PM
