Results 1 to 15 of 15
Thread: VE wheels on a VK?
    VK calais
    May 2006
    cranbourne
    Default VE wheels on a VK?
    i have a set of 18x8 wm caprice rims for my vk. i have been told that they would fit fine, but i just put them on and they rub on the strut where the spring sits. they have been spaced 4mm off the hub, but still just touch. has anyone overcome this problem or do i need a new set of wheels?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    The best way of fixing this problem is to buy wheels that are designed for your car. Spacers are dangerous and illegal, further more, if you have spaced it that far out and are still rubbing - these wheels are not good for your car.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vt v8
    Jul 2009
    just give the spring seat a hit up with a big hammar it works i done it just do it as much as you need to stop it rubbing
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by crumpet hunter View Post
    Woah - yet another rocket scientist in our midst.....
    Reaper
    Reapers Black VP SS
    thestig's Avatar
    thestig is offline The Horror
    BMW E34 535i M
    Jan 2008
    In the metaphorical driver's seat
    Red face
    I would have thought it better to buy a new car for the wheels.. Afterall the wheels would be worth more.
    L8r
    All you really need to know is...
    He's called The Stig!
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    after you do that if it doesn't work, get an angle grinder and cut off anything else that they hit on. As long as your car looks good for when you are on the news as another stupid accident.
    VH SL/E 308
    Aug 2009
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
    Quote Originally Posted by andrewp View Post
    Check the tyre size VE 18 have higher profile than VB to VZ.
    and different center bore and different stud size.
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    and check the width if you get a smaller width tyre the sidewall will stretch on meaning less side wall flex and also the sidewall will be pulled in instead of hanging over
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    you could also get the chasis off a landrover discovery and swap it for your k-frame.
    ive heard thats a quick fix.
    VK calais
    May 2006
    cranbourne
    the guy i bought them off told me they would have no problem on a vk, but apparently they only fit VN - VZ now, his story changed after i handed him the cash so i just bought different rims.
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by boogs86 View Post
    I highly doubt they fit on VN or VP as those front struts are essentially the same as VB-VL.
    Reaper
    Reapers Black VP SS
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    You will need to get the center of them bored out a little but will need the tyres off to do this. Don't bother putting the factory tyres back on because they will not fit. You will have to buy new tyres which have a smaller side wall and are not as wide in order for them to clear the guards/struts.
    shiftySLE's Avatar
    VH SLE, VZ Acclaim
    Jun 2009
  15. #15
    VN Calais
    Jan 2009
    Melbs
    Put them on ebay and get a correct fitting set Im afraid.....
  1. new wheels to replace 15"steel wheels
    By peewee in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-04-2009, 04:00 PM
  2. [VIC] Want to swap SS VE wheels for CalaisV Wheels
    By bigfut in forum Swap / Wanted to Buy / Trade
    Last Post: 17-02-2009, 06:23 PM
  3. different width wheels and flat bottom steering wheels?
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2006, 05:50 PM
  4. WTB: VZ calais wheels or other genuen holden wheels
    By commy92 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-06-2006, 06:08 PM
  5. VZ Calais wheels wanted - VY Berlina wheels for sale
    By I just want one in forum Swap / Wanted to Buy / Trade
    Last Post: 19-08-2005, 08:21 PM
