Results 1 to 8 of 8
Thread: thudding noise from rear of car
    jacob1986 Guest
    Default thudding noise from rear of car
    When I stop at lights or a stop sign or whatever and then take off, there is a thudding noise from the back of the car that almost sounds like your going over train tracks....any idea what it is ?
    SLE_304 Guest
    Quote Originally Posted by jacob1986
    sounds like the spider gears inside the diif are on thier way out.
    check for anything that may be loose like an exhaust or upper or lower control arms.
    good luck
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Also check for buggered tail shaft unis, or a tailshaft centre bearing it could be flogged out
    cheers
    Scott
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    also pop your boot and make sure there's nobody gaffa taped and hog tied inside thumping your bootlid trying to get out.....
    kooloo Guest
    i had the same symptoms on my vk a while ago... it was a the centre bearing
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    can be in the suspension. worn bits and pieces. also like the idea of checking for anythnig loose inteh boot.
    jacob1986 Guest
    Quote Originally Posted by kooloo
    thats what the guy at the repair shop said, that it isnt aligned, and when u take off it straightens up and the sound goes away....he was supposed to fix it but the noise still happens so Ill have to get back to him on that.
    Fat VB Guest
    Default tailshaft
    sound like a tailshaft uni or something in that area
  1. Thudding Sound
    By VRTurner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2007, 10:33 PM
  2. VR Thudding noise
    By johnmic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2007, 06:34 PM
  3. Noise from the rear axle
    By r_i_d_a_h in forum General
    Last Post: 03-09-2007, 06:58 PM
  4. 'thudding' noise
    By lieos in forum Car Audio
    Last Post: 16-07-2006, 04:33 PM
  5. Rear End Noise...
    By jwoods997 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2005, 10:26 PM
