Results 1 to 7 of 7
Thread: AC making awful noise VK
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Exclamation AC making awful noise VK
    i got a vk and the AC (i think) is making a terrible squealing noise when turned on or revved when ac is off.. would could this be??
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Could be the clutch bearing on the compressor, or a loose belt.
    MY RIDE
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    i was thinking belt untill i turned the ac on (usually just used window) and it squeeled like all hell
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    so does anyone know how to fix it?? the clutch i mean??
    thanks
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    so it squealed more with the ac on? sounds like the belt cause when the ac is on the pump is engaged and becomes harder to turn, thus y the car revs usually change with ac on. Just check how tight the belt is by pressing on it where it is in between the 2 pulleys and let us know how tight it is
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    yeah the belt is loose, spray some "stop squeel" on it, or if your feeling really dodgie, spray some rubber glue on it
    or maybe just adjust it... one fat-arse bolt on the pulley wheel, loosen the bolt, put pressure on the pulley wheel (opposite direction to the crank pulley), then tighten up the bolt.
    easy.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    thanks.. when you push the belt it moves about an inch, maybe a little less down..
  1. VS making engine noise
    By R33GTST in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2008, 05:05 PM
  2. VS making engine noise
    Last Post: 08-02-2008, 06:42 PM
  3. AC Compressor making noise VN
    By gap2crook_grind in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2007, 08:38 PM
  4. indercater making noise
    By manual VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2006, 10:19 PM
  5. vs ute making strange noise
    By MATT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2004, 07:11 PM
