Ok my novice is showing once again . dont peek,
the block i have in the VB is numbered VL 40852 (i have searched engine numbers and it says VL is a 5.7l block for a Vr vs this doesnt make sense considering I have a straight 6 )
I also have a Lumpy cam allegedly fom a LH or LX Torana
on the standard cam it has the GM marking on this Lh-LX cam the markings are A 9 and numbers on the reverse side
the inlet manifold on the vb stroker block is a Brand X alloy type I have not seen this before
also where can one see on line the break down of a 3.3 motor from the rocker cover down to sump with internal diagrams do these exist regards PJ
Fatman and Sons
Ok i worked the motor bit out VL is a 202 red blue black with carby i was reading some false info on another site
Fatman and Sons
