Sending the car to get painted and after removing the trims i lost a bit of paper with the colours.
im after the colour diagram for the REAR switches what colour goes to what pin
my colours are green yellow blue orange and purple the switch looks like this.
Cheers Oldschool.
come on guys help me out!
on my vb sle the coulors are on the back of the switch
not mine that paper has been ripped off any chance of having a look for me?
my colours are diffrent mine are yellow black.... blue... blue orange.... black.... yellow
i have the Gregorys book ill post back up here later on!
Budgies Car Sound
Facebook www.facebook.com/budgiescarsound
sweet thanks mate!
okay dude im going to re do it in paint with color codes.. my scanner dont work..
Budgies Car Sound
i got diagram for you but its diffrent.. look at your front window switch if it has same colors... if you have a multimeter test the switch.. i think the middle pin would be earthed or both the out side pins would be earthed.. i reckon the middle one would be earthed if it is a 3 way switch so for example if you push it forward window goes up if you push it back window goes down... now if it is like that i would put earth in middle pin and then the other 2 on the our sides.. switch it and see if it is correct of the button is around the wrong way just simply switch the out side wires around with each other..
if you have a master switch in the front of the car then there will be 5 wires going to the switch 2 going to the motor, 1 going to the override switch and 2 of them to the master switch...
as i said if your not sure and if you have a multi meter and no how to test for vualts do that and get some one sitting in the front to turn the mast switch on off on off to see what wire is what..
hope it helps dude.. the book doesnt say what pin and stuff and i have diffrent colored wires..
Budgies Car Sound
here ya go mate hope it helps
yeah thats what my book said dude.. but didnt have pic of switch nice post that should help ya heaps some wires are 2 colors!
Budgies Car Sound
vH Sl/e 81 cheers mate thats what i needed did you get that from the vh service manual? the white and blue covered one?
Anyway thanks for the help!
nah cant remember where i found this it was somewhere on the net though possibly someone on this forum..
