Results 1 to 13 of 13
Thread: EFI VK not starting.
    1988 VN Executive S1 and 1984 VK Executive
    Sep 2008
    South Australia
    Default EFI VK not starting.
    Greetings all, i've got a bit of a head scratchier here.
    My VK Exec won't start, the other day it was being driven on the fortnightly shopping run when it let lose a massive back-fire and lost all engine power. Since then me and my mate have gone through the motions and have come up with no obvious problems and every attempt to start it ends with the battery draining, any suggestions or advice would be greatly appropriated.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Turn the ignition on and see if you havefuel pressure you can press a pin on a valve on the front of the fuel rail.
    Next if you have fuel, pull a lead off and check for spark
    Next pull an injector plug off and fit a 12v 3w light bulb tot he injector plug and see if it flashes when you crank the engine.
    lso probably best to check for spark prior to checking for fuel pressure you dont want to ignite the fuel you spray in the engine bay
    post results
    Gse
    Gse is offline
    Opel Monza
    Jan 2006
    Check if the valve in the airflow meter can move easy without getting stuck...
    Sep 2008
    South Australia
    Thanks for the tips mate.
    I've checked for spark and fuel pressure, it got a strong spark and full pressure.
    Injector test was also good.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Sep 2008
    South Australia
    ari666's Avatar
    1966 impala
    Mar 2009
    Sep 2008
    South Australia
    OK, here's the latest.
    I managed to get it running for 10-12 seconds but it was running really rough and stalls whenever i put the foot down, when it was running for those few seconds it was blowing flames about 5 inches out the throttle body. (An awesome sight but that's not important.)
    Any ideas?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I would say timing first, block off the vac advance hose as well. Next if timing is ok AFM would be the issue
    scott
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    Sep 2008
    South Australia
    Quote Originally Posted by vkberlina View Post
    scott
    How would i go about adjusting the timing?
    ari666's Avatar
    1966 impala
    Mar 2009
    Sep 2008
    South Australia
    Problem solved, turns out it was a dodgy rotor button that was causing all the grief.
  1. vs not starting. help pls=(
    By edwardos11 in forum Electrical Wiring / Questions
    Last Post: 20-01-2009, 08:18 AM
  2. VN Not starting - HELP
    By ghosty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 01:27 PM
  3. Car not starting
    By mclutterham in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2007, 09:53 PM
  4. starting....
    By UnderPressure in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 04:39 PM
  5. Starting out first car a VS... Help!
    By Mattaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 10:54 PM
