hey i got a vb with a 253 and an aussie 4 speed in the shed and just wondering whether theres any more mods i can do to the motor so it actually moves haha before throwing a bigger one in there.
from memory it has:
quadrajet carby and standard 4 barrel manifold
hq cam timing gears
crow 5602 cam (not sure if thats what it is, i'll check it out)
hei dizzy
pacemaker extractors and free flow exhaust
at the moment, the engine comes into its power range at around 2700 - 2800 rpm. just after a bit more hp really, seems very flat, but it is only a 253.
diff gears will make it feel like it has a lot more pull
true that, its got the stock 6 cyl open diff haha 3.08 ratio i think... or is it shorter. already sits at 2750 at 100kph though, and im not keen to go down the highway at over 3 grand at 100 considered it only revs to 5500rpm.
yeah true that, i had 3.9's in an auto, close enough to 4000 on the hwy, fuel consumption dropped to a point where I nearly had to plan my trip from servo to servo, especially at todays prices
Find yourself a brock manifold. They flow a ton better than the stockies. Besides that, take it to a carby specialist and get the carb and dizzy tuned to suit your cam. You will be surprized at the results. As far as carbs go the quaddy is excellent, just make sure you find a specialist who knows about them.
Reaper
i've got another manifold sitting around in the shed at the moment but i think it would be a bit over the top for a 253 (edelbrock torker) being a single plane, but it might give me a bit more in the top of the rev range.
yeah i totally agree with the quaddy comment, my old man is running one on his 360 stroker in a hg wagon and hes been playing with them for probably 20 ish years haha, i got him to tune it.
Out of all the mods we done to our 253, I rekon the best improvement were the heads.....were only on there for a while then built up a 308. But yeah I'd recommend heads, but obviously ya need to look at everything else as well, like exhaust, carby, ignition to get the full benefits of decent heads. I'd recommend looking around for a decent 2nd hand set, coz getting professional headwork done is veeery expensive.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
308 possibly... lol
Good set of ignition.. and good tune.. remmber a 253 is only a destroked 308... everything is the same 253 (3.8inch bore) 308 (4inch bore ) manifold change exhaust set up?
Floor it and swerve driving skool
Memory of those things is fading but I'm sure you will find the bore size of the 253 is much smaller than the 308.
Reaper
Same bore as a 202, the stroke is the same as the 308 (but the crank is lighter). Ported heads, a small cam and a modified manifold to brock manifold spec will send a Torana well into the 13's
Come to think of it what you describe there is exactly what I had in one of my old Hatch backs.... It ran low 14's but hard launches were not possible due to the old Banjo type diff. 1 hard launch = whine. Second hard launch = massive bang and no go go. Fitted a 9" but smashed it before I could find out how fast it really would go.
Reaper
The Edelbrock torquers go really well on the 253's with a good mid range cam. Another quick and dirty technique to improve the standard manifold is to fit a 1/2" spacer without the centre divider between the carbie and the manifold. You can also machine out the divider in the manifold. This essentially creates a single plane manifold with a larger plenum area. It improves mid to high range, but low range suffers. The thicker the spacer the better the result. The only limiting factor with this is bonnet clearance.
The Holden V8s suffer from chronic valve train wear. If it has done a few miles it good practice to replace the lifters and re-seat the valves.
My Garage:
VZ SS 6ltr 6 speed silver
VN 5ltr 5 speed Gold (Ex NSWPF Highway Patrol)
VH EFI 5ltr Supra 5 speed tiger mica
XC Barina SRI 1.8ltr 5 speed silver
unhelpful, but meh...
a good strong rope is the best mod. that way your boat wont float away while you are fishing.
my mechanic swears a 253 is will hold down anything up to a 36 foot yacht, but he reckons they drag the riverbed if there is a strong current.
