Results 1 to 15 of 15
Thread: replacing spark plug
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Exclamation replacing spark plug
    i know this is pathetic but i dont know how to replace a spark plug on a car too well. ive only ever done it on planes. can you help
    thanks
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Do them one at a time, so you dont get the leads mixed up.
    Pull the lead off the plug, put spark plug socket on, and turn anti-clockwise, until it comes out. Install the new one by hand, making sure you get the thread tarted perfectly. Then do it up firm, and a tad more, its hard to explain, but dont over-tighten them, but make sure they are tight.
    If your worried you can use a torque wrench (specs are in the manual) so you get a feel of how tight they need to be.
    After you've done one, just plug the lead back on, and repeat for the next plug.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    straight forward
    1 remove ignition lead
    2 use spark plug socket and a ratchet
    3 remove spark plug
    4 replace by hand
    5 tighten plug firm
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by greenacc View Post
    grip it with your teeth and turn your head.
    thanks, im doing that now..
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    yer.. i got that bit but when i was doing work exp as a plane mechanic i used some like metallic paint on the thread
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by vkcommo View Post
    It was probably a never-sieze compound, Im guessing they have long intervals between changes or due to the extreme heat. Only guessing, I know fark all about planes, except I went on once But yeah no need for that on your car, just straight in.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    we change them quite regularly in planes. but will it do anything for the engine in the vk??
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Its probably a copper based never seize your thinking of. You can use it if you want but not necessary.
    Don't get it on your teeth tho !!
    VX SS
    Jul 2005
    East of Melbourne
    Slightly off topic, but I changed the plugs on the 202 VC a few months back and discovered the mechanic that did the last plug change had used the wrong plugs,
    he had used a short reach plug (I think from a V8) and the plugs had been firing in the
    threaded part of the plug hole instead of the combustion chamber, I got the new ones in ok but some were very tight due to the carbon in the thread, I had reason to pop a couple out the other day and whilst a few came out with no problems there were a couple that were very very tight, I started to remove them and thought this does not feel good so I did them up again and left well enough alone. Any thoughts on getting them out when the time comes for a change. Thought maybe if I worked them in and out gently they may come out.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    As greenacc said you can use it, but not necessary, personelly I wouldnt bother, its not needed, its more effort, and leaves one more thing to go wrong.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    was about to change them this weekend and then i realised that someone had stole the spark plug tool from my socket set...
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by Drewie View Post
    more than likely the washer on the base of the thread is jammed on the head and making it difficult to unscrew. just use a bit of brute force/ignorance, as long as you dont try and twist on an angle the plug shouldnt crack.
  15. #15
    97 magna
    Sep 2009
    most spark plugs these days already come pre gaped.
    so its simple as take out and put in.. if your going to change spark plugs your always best to change the leads and the dizzy cap while your at it.
  1. Spark plug GAP
    By Noy in forum V8 Development and Modification
    Last Post: 22-04-2009, 12:54 PM
  2. spark plug gap
    By mildewmatt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 03:49 PM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. Spark plug leads need replacing
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 07:18 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
