Results 1 to 8 of 8
Thread: No Air Con or Heater VH Wagon
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    Default No Air Con or Heater VH Wagon
    Since blowing my fusible link when i first got the car, i have no heater or air con. Im sure the air con wasnt workign when i got the car, but im certain the heater was. The fans work, but the is just no temperature adjustment, al lmy fuses seem fine, and the heater controls light up when i turn the lights on.
    Any ideaS?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    since the temperature is not controlled with fuses, i'd say it didnt work to start with.
    maybe check your vacuum hoses. they fall off or perish pretty often. but more likely your heater core is blocked
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    i flushed and reverse flushed the heater core, lots of brown crap came out, and the water was free flowing, but still no heater.............. the heater air con fuse gets really hot though when ive had the fan on full tilt
    VH Wagon SLX 253
    Nov 2004
    Southern Highlands
    ari666's Avatar
    1966 impala
    Mar 2009
    so the fan works but no heat?
    is it electrical swithed heat or vac controlled like the VK? check the temp switches.
    VS Calais & vh sl
    Dec 2006
    deception bay
    they are vac controlled so look for a cracked / perished or disconected vac line. also check if water is flow throught the heater lines before going through the firewall.
    ari666's Avatar
    1966 impala
    Mar 2009
    yep, what he said.
    plus the little selectors where all the vac lines go into tend to perish, so drop it out, start the car and stick your ear next to it. if you hear a sucking noise. get antother one
    vh commodore sl vacationer
    Aug 2009
    check thermostat thats my problem with my heater. does your temp guage work. earth it out to the motor to check
  1. vz wagon window washer-wagon
    By vsholdenguy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-06-2009, 08:27 PM
  2. VN V6 S1 Heater Tap
    By Bugsy27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2009, 11:05 PM
  3. Where is heater tap
    By viper05 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-05-2008, 11:31 AM
  4. Manual VT wagon or VX wagon + conversion?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2006, 11:09 PM
  5. Heater Core leaking VR 1994 Wagon, can't get it out
    By electradaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2005, 11:39 AM
