hey guys how are you?
anyways lately with this crap weather i have had a water leak under my glove box it is not the heater at all! the water is not coming from under the bonnet where the water passes though when it rains and im pretty sure it isn't the front window seal because its pretty sealed even though im going to get a new one just incase!
but for the left door it drips alot from the top could the water becoming from the door and leaking from under the glove box??
how can i make my door close a bit tighter because i can push on the door and it will move in where as the other doors there nice and sealed tight
hope it makes sense to you haha i never make sense!
thanks guys!
Budgies Car Sound
Facebook www.facebook.com/budgiescarsound
You will find either water is coming through the bonnet vents intot he plenum and down the heater air intake, or the windscreen is leaking and water is passing through there.
To adjust the door get an alan key and loosen the door striker and move it in and retighted.
cheers
Scott
okay cheers dude!
um the striker on the door? or is it the metal pole thing it catches on witch is on the car?
cant find any allen key screws eaither there phillips if there the ones i can see!
my name is also scott![]()
Budgies Car Sound
ahh cheers dude ill have a play with it after work thanks for your help..
that door is always a pain to close it closed but not all the way you have to be firm with it..
hopfuly it fixes that aswell..
Budgies Car Sound
