Results 1 to 12 of 12
Thread: need help asap...removing camshaft black 202
    VB SL commodore and VN s1 v6 5speed exec
    Apr 2009
    Airport west
    Default need help asap...removing camshaft black 202
    hi guys im trying to remove my cam from my vb it has a black 3.3 out of a vk
    i have goy the lifters up and ive started to slide out the shaft but its gotten stuck and wont move...have i missed somthing? and how do i get it the rest of the way out?
    cheers
    OzzRocker
    Fusion's Avatar
    Fusion is offline Awww I bent my wookie !
    1982 VH SL/X, 1997 SII Calais .
    Sep 2008
    Colac Vic.
    If it has already started to come out it should slide all the way out . Just need to be patient and take care not to wreck the cam bearings . just keep moving it slowly till it slides through the rest of the bearings .
    Cheers Mick .
    HOLDEN. Not just a car . But a way of life !
    It's in the blood and deep in the heart !
    Apr 2009
    Airport west
    VK sold.. VN3.8 and VX aclaim
    Aug 2009
    south auckland
    Apr 2009
    Airport west
    cant get grease on it it in the engine lol trying to get the bastard out...still cant either i think its getting stuck on one of the bearings...
    Fusion's Avatar
    Sep 2008
    Colac Vic.
    They can be a pain in the butt to get out . Keep trying
    What makes it hard is getting the cam to line up with all the bearings at once !
    Cheers Mick .
    Aug 2009
    south auckland
    Maybe seem like a stupid question,,is the motor striped? have you also removed the oil pump and not just the distributor? you nee to completely remove the oil pump housing from the block as both oil pump and dizzy share the same drive..
    Floor it and swerve driving skool
    Fusion's Avatar
    Sep 2008
    Colac Vic.
    Quote Originally Posted by NZVK308 View Post
    Good point ! I forgot about the oil pump
    Cheers Mick .
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
    LOL goodluck with it mate yeah lifters, dizzy & oil pump then you should be right
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    you got a spare head bolt laying around? when your cam journels meet up with the bearings they can get nearly impossible to pull through, especially if its a newer build.
    the trick is to stick a head bolt into the end of the cam to give you leverage. you need to keep the opposite end of the cam as high as you can while you twist it slighlty counter/clockwise.
    with twist/pull/lift it should pop out. but ya' gotta be real nice to it cos' the bearings dont like to meet gears suddenly.
    hope that helps a bit. we are talking 6 again which makes it two pistons short, but hopefully transferable
    jakbob's Avatar
    jakbob is offline Lighten up.
    VX SS, VC L, VK Vacationer
    Dec 2008
    I think the fuel pump would have to come out as well.
    Four commodores and counting.
    VT spac super6
    Nov 2008
    Riverton sa
    and pretty sure theres a retainer behind the timing gear that you have to undo through gear by getting it in the right spot
  1. Need pics of black outs, around window and boot asap
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-09-2008, 02:54 PM
  2. FS SA Gloss Black 304 Engine Covers ASAP
    By Holmez in forum Parts And Other Items For Sale
    Last Post: 14-09-2008, 11:07 PM
  3. Removing Black Strip
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2008, 04:24 PM
  4. Replies: 6
    Last Post: 10-09-2007, 10:00 AM
  5. Removing black dots?
    By ElDubya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2006, 02:10 AM
