Results 1 to 5 of 5
Thread: Engine removal thoughts
    VR Station Wagon
    Feb 2005
    Unhappy Engine removal thoughts
    Hey guys and gals,
    I have recently come in to ownership of two VH Commodores (cost me $500) the engine seems to be in not so great shape in the main car, its a 202 Red motor, i have another 202 Red motor sitting in my EK Ute and i was thinking of doing a swap over, but then i came to thinking, would it be possible to unbolt the top half of the engine and use it on the VH, the carby also seems quite rough on the VH and id like to use the utes carb, it has a choke though, what options do i have here? do i have to put a choke in the VH or is there an easier option? any help would be appreciated
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    well the easiest option would be to put a choke on the vh i thought they came out with them
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    shhh! a little known fact in the holden world is that the 308 delivers more power than the 202....
    put one in your x-mas stocking? (or chunakah)
    if you do go V8 i will even let you in on the secret of electric chokes ... shhhh!
    vk calais 5.0
    Mar 2009
    reynella sa
    ari666's Avatar
    1966 impala
    Mar 2009
    i love reading over what i wrote in a drunken state the night before *sigh* im such a smart arse, and i apologise.
    when you say "it has a choke" do you mean it has a manual choke? what type of carby is it? EFI only started in the VK correct? so i assume the VH is carby. why not just change all but the carbys. while they are off stick a 'fuel miser' kit through it and clean it up.
    i couldnt really give you advice without knowing the condition of the engine first. have you checked/changed;
    spark plugs
    leads
    dizzy cap
    oil and filter
    air filter
    petrol filter
    sprayed a good amount of carby cleaner in?
    checked the screw/bolts on the carb are tight? (they loosen after a while)
    checked the timing
    a general bolts check;
    inlet manifold
    exhaust manifold
    carby to inlet
    sump
    oil pump
    rocker cover
    checked that your alternator drive belt is tight
    air cond/power steer belts if you have them.
    checked radiator fluid and visually inspect radiator for leaks?
    check trans fluid if auto, check the fittings to the radiator.
    lol, looks like you have your work cut out for you. but all that stuff shouldnt take too long. once its done then you can get a better idea of the condition of the iside of the engine, since all the outside bases are covered.
  1. v6 engine removal. up to the last stage: mounts
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2009, 12:30 PM
  2. engine removal??
    By sandbar1000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-01-2009, 01:36 PM
  3. Urgent: Engine Removal
    By VH_Commie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-12-2007, 12:03 AM
  4. Aircon removal, better 4 the engine?
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-11-2007, 12:23 AM
  5. Engine removal
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2005, 11:13 AM
