Results 1 to 5 of 5
Thread: Vk wiper motor tired?
    VR Commodore
    Apr 2009
    Default Vk wiper motor tired?
    My mate has a VK and his wipers screach a bit. He has replaced the blades with 3 different types even right up to expensive teflon ones but the wipers are slow and grippy. I'm just wondering if anyone with a VK has similar problems? I'm not sure whether the wiring needs updating or the wiper motor needs an overhaul. Thanks.
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    VR Commodore
    Apr 2009
    It's not stuffed it's just really weak and I'm wondering if it is because of a current drop in the wiring or if you can rebuild the motor.
    vk calais 5.0
    Mar 2009
    reynella sa
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    you got a multi-meter? if so you can measure the volts to the wiper motor with it engaged. but nay-say to that shite, if the blades screech then they are worn out, if they are new then your screen is prolly pitted. do yourself a favour and grab a buff with a nice gause pad, (i.e. the green stuff you wash dishes with) and run it on slow speed with a really coarse cutting compound. that will hopefully get rid of ull the undulations*in your screen which will make the surface smoother
    undulations IS a word, go look it up :P
    if you have not got any of that stuff go pay a guy to do it for you.
    *edit cos' of beer; yes my blades run slow all the time cos i have a mental voltage problem due to thermo fans/2xelectric fuel pumps/spastic stereo but i doubt yours is the same. you can measure the voltage at the wiper motor, but knowing there isnt enough volts at the engine is only the very beginning of the problem. seeking the answer usually means spending about 300 bucks on new electricals. and adding a relay wont do jack-all. also wiper motors are usually tough as f... so i would look at your glass before your motor.
  1. Wiper Motor
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2009, 09:57 PM
  2. wiper motor replacement
    By half-fix in forum General
    Last Post: 12-01-2009, 11:00 PM
  3. VH wiper motor
    By stubang in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2008, 11:45 AM
  4. Wiper Motor..
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 09:56 AM
  5. vc wiper motor
    By -vkhg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-08-2007, 11:21 PM
Tags for this Thread
