Results 1 to 12 of 12
Thread: What tail shaft to use in vk with efi v8
    VK Calais EFI 6 now vp 5.0l and t700
    Dec 2008
    victoria
    Default What tail shaft to use in vk with efi v8
    Hi i have a 84 vk calais and i am putting in a vn v8 and t700 auto in. I already have a crs cross member and speedo cable suit. I was wondering what tail shaft would fit in. I was hoping that i could get a front section from the wreckers to bolt up. Any help appreciated
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    as far as i know all VK's were fitted with trimatic pattern, so the tailshaft needs to be shortened and the turbo spline needs to be welded on. you could prolly look around for a VB or similar with a turbo trans and just use that. it would prolly be alot easier and cheaper but i am not sure if the yolks are the same,
    vb turbo pattern have 10 bolt big salisburys? im not sure.
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I asked a mate some questions about the trans for my conversion and here's wat he told me. To start with, the T700's are crap, get a T350. The T350 will bolt up to the EFI block (obviously), and ya can use the trimatic tailshaft coz the boxes are pretty much the same size. And coz it's smaller ya can also run manual steering and also have more clearance for the exhaust. Commodores have a 2nd set of mounting holes for the trans crossmember, use the standard trimatic crossmember and mount it in the 2nd holes and it fits the turbo boxes.
    So a lot of the custom work involved when dropping an EFI 304 in ur car can be cut out if u change to a T350.
    vk calais 5.0
    Mar 2009
    reynella sa
    yes im so happy then so i dont have to get a new tailshaft yet? or get a different crossmember? is the 2nd set of holes visible or do you have to scrape some shit off?
    vk calais 5.0
    Mar 2009
    reynella sa
    Dec 2008
    victoria
    I already have the turbo 700 and everything except the tail shaft for the conversion. I know the auto arn't the most reliable it you give them a hard time but i want the 4 speed for the better fuel economy.
    RVK 355's Avatar
    RVK 355 is offline M0DERAT0R
    The real R series 355
    Aug 2006
    Quote Originally Posted by v8commy View Post
    would i be able to use a t700 crossmember on a t350?
    No.
    Use a 6cly trimatic rear cross member.
    RVK 355's Avatar
    Aug 2006
    Quote Originally Posted by MAHOOVKV8 View Post
    use the T700 front tail shaft out of a VN V8 bolted up to the rear half of your tail shaft
    Dec 2008
    victoria
    vt ss & lc gtr
    Jan 2006
    Trimatic tailshaft looks a tad too long when you fit it up to the car so use the th700 front half with your back half.
    My trimatic shaft fitted up to the car with the yoke practically bottoming out in th700,I reckon it would chew out the front uni or centre bearing if not damage the auto if you used it.
    Dec 2008
    victoria
    Thanks gtrboyy. nice torana
  1. some one help me!!!!!!! i need a tail shaft
    By tadpol88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-08-2009, 11:43 PM
  2. tail shaft
    By tenggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2009, 02:44 PM
  3. tail shaft IRS
    By LOWPSI in forum General Discussion
    Last Post: 15-05-2008, 09:26 PM
  4. Tail shaft
    By Idenity Crisis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2007, 09:41 PM
  5. VB Tail Shaft
    By B.C in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-04-2007, 10:14 AM
