i just got a t350 for $50 with a 308 adapter and 2800 hi stall got quoted $1750 for a hd rebuild i just wanna know if i can use my same tailshaft from my trimatic? if i can use the same crossmember from my trimatic? if i can use the selector off my trimatic? how do i get the speedo working as i have an electronic dash? all help will be highly appreciated
anyone know?
Turbos may have a different spline, put your tailshaft in and see if it mesh's, also, it might need to be lengthen or shortened, not sure which and if its necessary, regulations say that you need to push the spline all the way in, then out 15mm I think. 350's have a screw on speedo, however they also come with the same as the trimatic where you push it in and secure it with a small metal tab, crossmembers are interchangeable but the box may sit a bit higher, they should line up. I know its a lot of maybes but the best way would be to get the right crossmember and other parts.
Keep in mind, adapter plates are not the best option as if they are not set up to the mm, you will chew out the pump and converter and you'll get an annoying vibration.
The rebuild price is very fair assuming its with a shift kit as well.
Finally, be careful with second hand stalls.
Good luck, I hope this helps.
yeh the rebuild is with a shift kit ive heard the tailshaft will fit but there to long? and could **** the rear seal up and also heard i could use my same crossmember i might give a few transmission shops a call and get the full lowdown on the situation
aww didnt mean to be rude thanks for the help shifty
no probs, the tailshaft should fit but the clearances where you might have the problem, I encourage you to ask an auto shop as that way you know for sure. This info came from a mate that did the job a few years ago and about 7 cars since then so even he was a bit unsure.
All I can say is Turbo 350 for $50, Well done mate, that's a killer price, 300-400 is about the going price.
Just remember to ask about the adapter plate, pumps and converters are expensive as they are box out jobs.
Let me know what they say just out of interest.
will do mate
