Results 1 to 2 of 2
Thread: VH needs help ASAP dash+water leak
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    Default VH needs help ASAP dash+water leak
    okay i posted a thread a while back about a water leak i had coming from the left hand side under glove box compartment.. its gotten worse i have a puddle!!!!
    i found one of the leaks witch is where the antenna and electric aerial cables run though thats an eays fix! how hard is it to take off the front left panel? and do i have to use silicon to seal it up... okay next..
    the other water leak is coming from the top some where and i am very certain it is not the front window seal (i could be wrong) someone said it could be coming from the air/intake for aircon and heater but i dont beleive that because then it would be leaking into the heater motor??
    here is a picture i took from underneaith the glove compartment i have drawn lines where the water is dripping!
    and if you guys could please link me to a how to guide, to take my dash out to find it because in the same process i will be cleaning it re wireing it ect...
    thanks guys!!
    Budgies Car Sound
    Facebook www.facebook.com/budgiescarsound
    VX 'S' S1
    Apr 2005
    South East,Victoria
    In production there is a blob of white sealer applied between the firewall and inner guard to seal the panel join which over time hardens and crumbles Take off the front guard and clean up the area and put some rust converter on the area and apply more sealer .
  1. Water Leak...
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2009, 02:57 PM
  2. need help asap auto leak
    By 94calais in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 04:55 PM
  3. water leak
    By newbee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2008, 07:44 PM
  4. ADVICE ASAP: Power Steering Leak
    By nickbalcombe99 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-06-2006, 08:26 AM
  5. Water leak under dash
    By budge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:01 PM
