Results 1 to 5 of 5
Thread: Using A Switch To Turn Reverse Lights On
    83 VH Holden Commodore Vacationer
    Sep 2009
    Default Using A Switch To Turn Reverse Lights On
    Hey everyone
    I found out from the auto electrician that apparently something in my gearbox is worn but considering its not slipping or nothing. My issue is that my reverse lights go on when its in 1st/2nd gear or touching the left side of the gear stick so was wondering how would I go about making a switch to turn them on to get the cops off my back if they wanna see them.. can i just hook up power through the radio ignition wire and earth it out on the switch that way so the globes light up ?
    Michael
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    what car and gear box do you have? i have a VH commodore with a 4 speed manual and i had the same problem then my revers lights stoped working.. all i did was get under neith my car and you will see something with 2 wires poking out just unplug it and take it out with a socket set and buy a new one.. put it back in if you are going to drive around though.
    i was lucky to find a switch at pick-a-part that came out of the same gear box..
    good luck and let me know how you go!
    budgie.
    Budgies Car Sound
    Facebook www.facebook.com/budgiescarsound
    Sep 2009
    same. 4 speed manual vh commodore. i took it to the auto electrician and they replaced the switch bit but reckon its something more than that in the gear box cause it turns on from 1st to 2nd gear and in neutral if touching on the left side
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    i dont know if a random switch will satisfy a cops 'roadworthy-itis'* i am pretty sure the lights have to come on passivley once the gear is placed in reverse.
    sorry i cant be more helpful than that. i would be wondering; if that part of your box is worn, then what else is. since i cant see it being more than a metal lug contacting a plastic switch.
    reckon you should get a 2nd opinion, personally.
    *roadworthy-itis; a debilitating disease in which a cop suddenly thinks he is an aeronautical engineer and knows more about your ride than you do. once fully infected, symptoms are, lack of ability to drive after business hours and a yellow blemish on ones windscreen. only known cure is a green piece of paper provided by a medic of mechanical prowess.
    budgieVH's Avatar
    May 2009
    Australia
    if you take your center console out and take the rubbers off the gear box (the seals from inside the car) and you will see a white plastic thing on top.. you have to push the nob down and into the top left corner so its under the plastic.. maybe the plastic could be damaged?..
    the switch isn't plastic here is a pic below of my old switch i pulled out!
    (i think my gear box is on the way out, it sound like a truck when idling sometimes =( !)
    Budgies Car Sound
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  3. Using A Switch To Turn Reverse Lights On
    By mrvdv85 in forum Electrical Wiring / Questions
    Last Post: 20-09-2009, 10:50 AM
  4. Headlight Switch Can only turn on parkers.
    By ZeakX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2007, 07:59 PM
  5. reverse lights wont turn off
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2006, 08:31 PM
