hey guys i recently put a vr v8 booster and new big master cyl (brock) on my vk calais .Everything bled up well .theres no air good flow outa every caliper.. but for some reason my master cyl seems to be preasurising or something ? somehow brake fluid seems to be weaping outa the cap then running down the booster and ****ing the paint.
has anyone come across this before??????????????![]()
yeh you have to much system pressure did you bleed you mc before fitting it? is your fluid level to high?
Yeah i gave at a bit of a bench bleed and i even removed some brake fluid from the rear half of the mc to see if that stoped it but it still leaks!!!!!!!!! ill pull it back off and bleed the f@#ck out of it again
