Results 1 to 6 of 6
Thread: Vk vacuum type cluster Help!
    VG
    May 2009
    Grafton
    Default Vk vacuum type cluster Help!
    Hello
    My vk when idle reads arround 5000rpm??? when u put foot down goes all over place.. When u gun it goes straight to 1000rpms??
    Is this normal or wtf?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Thats probably because you have a vacume guage not a tacho, you will notice the scale is in inches of mercury or Hg for short.
    cheers
    Scott
    VG
    May 2009
    Grafton
    hi
    its an original cluster from another vk.. same as what was in it before... the part that reads your "power" is measured in vacuum x10kPa
    its not a tacho at all .. now that im looking at it it says economy, vacuum x10kpa, and under number 1 it says power and is red and as you get up through the gauge it goes from red back to white. sort of the opposite as a rev meter which goes to red as you get up higher. does this make any sense to anyone?
    mightyredvc's Avatar
    mightyredvc is offline feel the fury
    83 vh sl/x (mid build)
    Oct 2005
    hobart
    as vkberlina stated, it is a vacuum gauge not a tacho, and is most commonly called the useless gauge. it mainly lets you know that every thing is ok in the intake path. if it drops at idle to 2 or 3 it means you have a vacuum leak in the manifold or carb, or if it drops when breaking it can mean the booster is leaking. basically if its steady and reading about 5 or 6 at idle all ok. it's also supposed to help you monitor fuel useage, the lower the number the more fuel being used. hope this helps
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    VG
    May 2009
    Grafton
    Thanks everyone
    My 1st vk so wasnt sure what the go was didnt understand the vacuum side of it.. Cheers mighty
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. vacuum
    By tenggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2009, 06:11 PM
  3. VS air con vacuum help
    By Nexxo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2008, 06:36 PM
  4. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  5. airflow controller not working - vacuum cluster problem?
    By catalyst55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 01:18 PM
