Will the door trims of a vk wagon fit a vk sedan?
Thank you
yep no different
GEELONG PREMIERS 09
Door trims from VB to VL are all interchangable
Thanks guys.
Wats decent price i should pay for full set door trims?
Sorry but everyone is wrong the sedan to wagon are slightly different. the felt strip along the top of the door trim on the rear doors is slightly too longto fit a sedan correctly and will need to be trimmed down.
also if your interested in trims I havea set o calais & berlina trims I need to get rid of gong cheap if your intersted.
cheers
scott
I put VL sedan trims in my VK wagz.....they can't be too much different coz I didn't notice any difference with the felt strip. Not saying it's not different, just saying it's prolly not very noticable.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
Thanks guys
Last edited by Dayvo; 22-09-2009 at 09:49 PM. Reason: can't eat and type at the same time
Positive enough to say that every one else is wrong. The door skins may be the same but the dr frames are not and are only slightly differentto require diferent lengths & positioning of the felts on the rear door rims. The different is slight edan will fit wagon but wagon won fit sedan withotsome trimming.
scott
Ahh , it could be that the door frame near the end that has the small quarter window on a sedan is a different angle to the wagon .Also there was a small sheet metal plate welded under the quarter window later in production as an anti theft deterent. Maybe the felt was made shorter to compensate for this.
