Results 1 to 7 of 7
Thread: VH Exhaust Manifold
    83 VH Holden Commodore Vacationer
    Sep 2009
    Default VH Exhaust Manifold
    hey all
    does anyone know which bolts to undo when changing a exhaust manifold gasket on a blue 202 motor in a VH Commodore? i got some type of instructions but just need to know which exact bolts to undo.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    ummm, all of them?
    lol, what do you mean? you will need to get the whole manifold off to clean and prep the block and manifold surfaces anyway... i think there are two flange bolts and about 2 bolts for every port...
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    On the VH there are 4 flange nuts as it is a twin header pipe assembly, then there are 8 nuts that hold the intake/exhaust manifold assembly to the head. You will have to remove the carby to get the two nuts under the heat shield.
    They have a bad tendency to leak at the heat riser box too, to you may have to separate the manifolds and replace that gasket too. Worse case scenario, the heat riser box contact surfaces have warped so you may have to fit extractors.
    Visit my Facebook page
    Sep 2009
    just replaced the flange gasket and it runs beautiful now still a tiny leak in the other part above the flange where that spring bit is but aprt from that it runs fine
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    So you didn't take the butterfly off and replace the bigger flat gasket under that?
    Sep 2009
    yeah i did, but its being a bit stupid at the moment, i might need another manifold cause its got a threaded bolt which just keeps turning whether you undo it or do it up
    ari666's Avatar
    1966 impala
    Mar 2009
    drill out the hole, put a longer bolt on it and use a new nut
  1. odd vn s1 exhaust manifold
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2009, 08:11 PM
  2. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  3. VR V6 exhaust Manifold
    By fitykemp in forum Parts And Other Items For Sale
    Last Post: 03-03-2006, 12:05 PM
  4. exhaust manifold
    By 80shovelead in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2005, 11:08 PM
  5. WTB VR exhaust manifold
    By 9psi-vr in forum Swap / Wanted to Buy / Trade
    Last Post: 16-09-2005, 12:56 AM
