hey all
some times when I brake with ignition on, my right indicator gets stuck on, then i play with the wires like shake them or move them and it stops, and i changed the earth spots. what could be making this happen ?
probably a bad earth or other connection. Get some contact cleaner and spray the connections. Hopefully this will solve the problem
ok, little more detail pls.
1. the indicator stalk gets stuck on? or just the light, it get stuck flashing or solidly lit?
2. what 'wires' are you playing with?
3. what do you mean "and i changed the earth spots"
answering these will help to identify your problem a lot quicker
def going to be an earth fault or brake lamp wiring has short to indicator wiring
