Hi guys
i own a 1979 vb commodore it has a black 3.3 six instead of the red 202 mods so far are crane hydraulic cam, crow lifters and pushrods, custom made tuned length extractors, redline intake manifold and a 350 holley.
my next mod i wanna do is supercharging i allready know how im going to set it up but i was wondering if there is anything else i should mod before i go bolting a supercharger on
cheers
OzzRocker
how much power you wanting out the blower? you can get away with puttn it on a stock motor depending how much you want out of it
BAD COP!! NO DONUT!!
yep.
1. fuel delivery, fuel pump, carby??! fuel lines, regulator,
2. internals, crank, pistons, rods, rod bolts, main bolts and caps
3. head gasket
3.a. head bolts
4. current CR is?
5. cooling system
6. brakes
7. ignition, spark plugs
8. intake cooling (not really all that necessary)
9. oiling system
10.ummmm
is that enough? i think your gonna struggle to make power out of one without sussing the above stuff. either a risk of it not doing anything but pinging, or popping something real quick
it would take a sh**load of work. much essier to even do a 3.8 conversion
as ari666 said there is going to be alot of work involved, i looked at this option with my old vk and it ended up been cheaper to do a injected 5 litre conversion because it involved basically the same things
