Results 1 to 3 of 3
Thread: vk running rich
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Default vk running rich
    hey
    was changing the spark plugs the other day and noticed alot of carbon buildup on the plug. this means its running rich(doesn't it?)
    how do i go about making it run normal (not rich)
    its a black 202 carbed
    thanks guys
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    get a vacuum guage. plug it in to the full vacumm port, put the car in D with a friend braking for you (or a block of wood between the brake pedal and seat, like i do) or neutral for manual trans. there are two mixture screws, depending on which carby you have, no idea where they are, sorry, turn one in 1/4 of a turn, then the other exactly the same amount. sit and watch the vac guage.
    if the vacuum went up, try turning 1/4 turn more on both, when the vac gets unsteady or drops down then unscrew the screws till you get the highest STABLE vacuum. you need a bit of patience to do this.
    realistically you would have checked everything else b4 you do that though, i.e. timing, spark gap and condition, dizzy cap, leads etc etc etc.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    ok.. thanks will try that
  1. PLEASE HELP!!...i think im running rich
    By JEZIMP in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2009, 12:48 PM
  2. vp running rich
    By blockhanson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2009, 07:29 PM
  3. Running Rich Y?
    By CNULTR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-03-2009, 01:25 PM
  4. Running Rich
    By ash72 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-03-2008, 06:00 PM
  5. VN 5L running way too rich
    By vkberlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2005, 12:32 PM
