Results 1 to 13 of 13
Thread: Oil
    83 VH Holden Commodore Vacationer
    Sep 2009
    Default Oil
    Hey all
    just wondering whats the best things to replace where you check the dip stick and the oil is like 2cm registering then it goes down a bit at a time? my oil is about half a half a cm but cant find any leaks.
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    if there are no visable leaks then your engine is burning oil
    if this is the case then it's time for a rebuild
    if you can see oil leaking then replace the gasket it's leaking from
    Bella - VK Wagon
    Dec 2007
    Make a visible inspection and see if there is anywhere noticable leaking oil. ie. Transmission/Sump etc.
    If there is no visible leaks than like what dyno suggested it may be that the engine is burning oil, if thats the case I would take it to a mechanic before it does any excessive damage.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by mrvdv85 View Post
    Hey all
    honestly... could you guys understand that?
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    for those wondering, half a half a cm is usually known as a quarter of a cm or 25mm.
    VZ S
    Sep 2005
    Queensland
    Quote Originally Posted by vlv8vic View Post
    25 mm is a quarter of 10 cm
    2.5 mm is a quarter of a cm
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Quote Originally Posted by gopher View Post
    I can't even blame tiredness today. Beats a half of a half though, gotta gimme that.
    lol
    VZ S
    Sep 2005
    Queensland
    lol
    yeah i couldn't believe that one also
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    oh i can believe i missed a 4 pixel dot, just unfortunate it happened during a terrific correction opportunity at a really.... interesting.... description of portion.
    Well spotted. Here's a spare for good measure ---> .
    ari666's Avatar
    1966 impala
    Mar 2009
    VX SS
    Jul 2005
    East of Melbourne
    If it's burning a bit of oil it may need a slightly heavier grade of oil in it, try and find out what grade of oil is in it at the moment and maybe move up to the next weight.
    The oil you are using may be too thin.
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    I'd say the OP accidentally wrote 'half a' twice by accident, geez give him a chance to stuff up as most people do sometime like calling a quarter of a cm 25mm.
    Anyway, I'd say being a VH the rings would be worn after many years of use. Try Drewie's advice and go for GTX2 oil or similar which states that it is for older and worn engines being that it is a heavier (thicker) oil.
    First off, I would jet wash the engine and look for any obvious leaks.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    also try putting/replacing the gasket on the sump plug.. about 5$ for a pack of 10 at super cheap and they fit all plugs.. well worth the money
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
