Results 1 to 3 of 3
Thread: vk v8 wagon.... leaking fluids problems!! help plz
    JLOWE is offline JLOWE
    vs executive s2 1996 sedan
    Apr 2009
    VIC
    Default vk v8 wagon.... leaking fluids problems!! help plz
    hey everyone i need some help with my brothers vk... he just rebuilt the motor and got it going now its leaking some kind of fluid... not using oil or power steering but leaking from front of gear box behind engine... and it is using trans fluid... if you's can help me it would be much appreciated....
    thanks jason
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    ummm, leaking trans fluid? is it red? same stuff as power steering fluid. i am guessing that he needs to replace the front seal on the trans. then again there are all sorts of places transmissions can leak from, the vacuum actuator, trans cooling lines, hell even the linkages can leak.
    get it up in the air and have a poke round the trans. take the dust cover off so you can see right up behind the torque converter. check all your trans lines. then tell us what you found and we will tell ya' how to fix it
    Apr 2009
    VIC
    thanks mate i'll check out all them possible problems lol...
    thanks jason
  1. i need fluids!
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2009, 09:23 AM
  2. help vz wagon roof leaking!
    By raptor666 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-10-2008, 09:07 PM
  3. vx2 wagon leaking
    By mick555 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2007, 07:54 PM
  4. changing fluids
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-05-2006, 11:21 PM
  5. Heater Core leaking VR 1994 Wagon, can't get it out
    By electradaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-08-2005, 11:39 AM
