g'day lads...my turbo 400 shit itself...soooooo, what gearboxes mate up to the turbo pattern, 400's are expensive and hard to find and 3 speed is kinda lame, so i wouldnt mind chasing a manual conversion.
any help would be sweet, cheers lads.
Need some parts for my VH 253:
Green standard steering wheel...Green lower B-pillar covers.
Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
PM with any info.
T5 manuals do.
the same t5's as on the 3.8 or 304 motor? cos didnt they use t5 for everything up to the vt's.
PM with any info.
Just use a TH700(as used in the VN/VP commadores..4spd auto vacume controlled...Take into account bellhousing to tail shaft length...TH400 is half inch longer than TH350 ( if i remmber rightly )
Floor it and swerve driving skool
Apparently the TH700's are pretty weak too tho.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
yeah all im looking for is a cheap replacement for my arsed t400...dont want to go into massive modification, aside from mounting clutch pedal box and such.
PM with any info.
