hey
whats the process of removing all the seats in a vk sedan>>
thanks
The rear back rest seats just pop out lift up then the bottom corners should pop out of the inserts.. the front seats use cap bolts to bolt seat to rails.. or just unbolt lock nuts from underside of the car and lift out..
Floor it and swerve driving skool
thanks.. i was looking all over for bolts on the back seats.. su(so) just putt(pull) and it will come out
things in brackets equals edits to show my bad spelling
The back seat is easy..... once you know how to do it lol.
The easiest, is put your hands in between the top and bottom half join crack, grab the bottom seat and pull it up. Once its up, you can move the front part of of the bracket. Then grab the vertical part and kinda pull it up, it will come off.
ok.. so you mean lift it up towards the rear screen/roof?? take off the arse or back part first??
yup just pay to double check in the boot.. along the back bracing that it doesnt have a couple of retaining bolts holding the back seat rest in place... allso once you removed the top half.. check along the bottom of the bottom half on each corner there isnt a bolt in each clamp.. some have them some dont depends if the seats have been removed and replaced in a previous life..
ok.. thanks
but then again i like the look of the 68ish ones as well?? i cant decide
