Results 1 to 18 of 18
Thread: thermo fans
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    Default thermo fans
    getting a 140a alternator today so i wanna put in some thermo fans anyone have suggestions on what size and or what cars i can get some off or where i can get some cheap all help is appreciated
    VH + VK Gas Cars
    May 2004
    I picked up a set of brand new mondeo style fans off ebay, came with relays,fuses and all wiring required.
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Wink
    I have used a single 16" davies craig thermo with their controller unit, worked great on my 5.0L with our supercharger fitted on her, never went over 1/4 on the gauge.
    Or
    VT or AU ( FORD) twin thermo's from wreckers??
    Micky.D
    YT
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by philbio View Post
    what size? 10"?
    VH + VK Gas Cars
    May 2004
    vk calais 5.0
    Mar 2009
    reynella sa
    VH + VK Gas Cars
    May 2004
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    craig davies make two great fans which are 16 inch and you offset them so the whole radiator is covered, then you can ditch your shroud.
    mine are currently set up-stream, which is on the engine side of the radiator and sucking the air through, but they recommend you set them down-stream and blowing. they are pretty expensive though.
    vk calais 5.0
    Mar 2009
    reynella sa
    well im picking up a set of el twin thermo's today who knows how to mount them apparently i cant use the pull through radiator clips (like zip ties)
    VH + VK Gas Cars
    May 2004
    el are too big for VK. The fans hang over the edge of the radiator and you end up pulling air through the sides instead of through the radiator.
    vk calais 5.0
    Mar 2009
    reynella sa
    RVK 355's Avatar
    RVK 355 is offline M0DERAT0R
    The real R series 355
    Aug 2006
    They are,but i just used some foam rubber to seal the gaps up
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by RVK 355 View Post
    smart thinking and they dont hang over they just reach the edge of the radiator
    ari666's Avatar
    1966 impala
    Mar 2009
    hey, dont forget that your radiator sits in a channel (radiator support) so it will hit the fan when you try and put the rad back in.
    dummy fit the fans while the rad is in the car to make sure, but yeah bigger is better IMO as long as it seals up ok.
  15. #15
    vk calais 5.0
    Mar 2009
    reynella sa
    yeh but there to big i tryd them in the engine bay with all the trans and rad lines hooked up and they dont even fit would they fit if i seperated them and put them diagonally? coz im heading in the direction where if they both dont go in only one is going in and i dunno if thats enough to cool it please someone respond soon
  16. #16
    vk calais 5.0
    Mar 2009
    reynella sa
  17. #17
    the lightning
    Jun 2005
    under the Southern Cross
    run the twin mondeos, they fit up nicely in the early girls. you'll also need to bypass the trans oil cooler in the radiator and run an external one.
    Quote Originally Posted by one_and_only2004 View Post
    Sounds like you and your friend have a collective intelligence rivalling that of a door knob. Looks like the useless crap you fit to your car is the driver.
  18. #18
    vk calais 5.0
    Mar 2009
    reynella sa
    nah im just gonna get a flexi fan i only wanted thermos to get rid of the clutch fan noise its horrible thanks guys for ya help
  1. Thermo fans into a VC
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2009, 02:46 PM
  2. thermo fans
    By jonohall in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2008, 02:19 PM
  3. Thermo fans
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 03:19 PM
  4. thermo fans
    Last Post: 16-04-2007, 09:37 PM
