Can anyone tell me how i would go about resetting the Idle Speed on my 3.3L EFI?
Unless someone has altered it it is pre set and something else is causing it to idle too high or low.
Dirty throttle body
Dirty Air Flow Meter
Timing
Vacume leak
Otherwise
There is a threaded screw with a lock nut on the top of the throttle body, back the nut off an adjust the screw.
Scott
